Need some help with an Oxygen Sensor
Old Oct 24, 2009 | 09:38 AM
craigmack14's Avatar
New User
Default Need some help with an Oxygen Sensor
Hi guys,
I have a 2003 RSX-Type S
My CEL just recently came on and when I took it to AutoZone, they said I needed to replace the oxygen sensor in bank one. I think the code was P0134. They recommended the Bosch 13680 sensor.
Some questions:
1) Is the Bosch sensor a good replacement or I heard the Denso one was better
2) Where exactly is the sensor I need to replace. Pictures?
3) any special instructions in replacing the sensor. is it easy to do myself?
Thanks for the help guys
Craig
Old Oct 24, 2009 | 10:42 AM
MarioTKR97EK's Avatar
Default Re: Need some help with an Oxygen Sensor
are you sure its an O2 sensor? cause i had the same problem changed the first sensor which was supposedly "bad" with a new bosch sensor, so after i changed it my car was worse untill i found out it was not the O2 sensor it turned out to be the air flow sensor i think it called, it goes on the headers i believe, anyways i thought i just give you a heads up on that as i had to go thru it i have an 02 RSX type S myself
Old Oct 24, 2009 | 02:49 PM
hawaiiancb74's Avatar
use denso and buy it from sparkplugs.com
Old Oct 26, 2009 | 06:58 AM
WhiteOnRice's Avatar
I had this code about 4 months back. I reset the ecu and it never came back. Dramatic weather changes can trigger the code I've heard.
Old Oct 26, 2009 | 11:49 AM
SkoundrelUSA's Avatar
cute little bastard
x2
Bosch sucks and prob costs an arm and a leg from VatoZone
Old Nov 2, 2009 | 05:08 PM
dc5mizz's Avatar
Originally Posted by SkoundrelUSA
x2
amen to that
Silver17
Honda CR-V & Element
Dec 31, 2019 02:53 PM
dez6
May 17, 2013 01:29 AM
mar7pau
Aug 29, 2010 10:34 AM
rasta420
Jun 8, 2007 01:59 PM
