jdm gsr motor
Old Oct 24, 2009 | 12:25 AM
wonTuansoup's Avatar
Default jdm gsr motor
Hi guys i have a question in regards of swapping a motor.
Car: 1997 integra 0bd2
im concerned about dropping in a JDM GSR 0bd2 motor in.
What tweaks would i have to do to make the swap done right?
Wiring: does it need to be lengthen?
OR what if i buy a 0bd1 JDM GSR motor
What would be needed to make the car run like it would swapped.
I know it bolts right on, is there additional sensors or wiring that i have to mess with?
Thanks in advance, Tuan
Old Oct 25, 2009 | 07:41 AM
Default Re: jdm gsr motor
TTT
Old Oct 25, 2009 | 09:34 AM
Brice.Hayden's Avatar
no you dont have to do anything. it will work perfectly.
Old Oct 25, 2009 | 03:33 PM
xero_xero's Avatar
Be specific in what you want.
Question: is your car a gsr, ls, or zc dual cam?
if you currently have an ls or zc, then you would have to wire for vtec. your best bet will be to use the obd1 harness for an obd1 swap. it will simplify the wiring for you if you plan to do it yourself.
if you have specific quetions feel free to ask.
Old Oct 25, 2009 | 04:55 PM
SplitDecision's Avatar
I put a b18c in my 95 gsr. My only issue was with using the jdm ecu there was a speed limiter (not that big a deal). I put my b18c1 in my friends LS and had to add around 5 wires.
vtec selenoid to A4
vtec oil pressure to ds
vtec ground
knock sensor to d3
secondary intake to a17
Old Oct 25, 2009 | 05:21 PM
Rajin's Avatar
Swap motor make mistakes. Learn your ****ing self.
Its straight forward, the only time you have issues is if you swap OBDs and then its only minor.
Old Oct 25, 2009 | 07:48 PM
SpEeDyX's Avatar
true story.....thats how i learned with the same type of motor too lol
Old Oct 26, 2009 | 05:52 PM
I'm just planning ahead, but thanks for the advice dick.
The car is obd2 with a B20 swap.
Everything is stock.
Now i just want to know if the jdm wiring harness, is it needed?
How would i have to modify it to place it into the car?
I'm assuming that you need to lengthen the wires, but i'm not sure.
Any advice would be nice. Thanks in advance.
BTW, if you don't have anything nice to say, then don't say it at all.
No one is perfect in this world.
Old Oct 26, 2009 | 08:26 PM
SpEeDyX's Avatar
LOL what are we in elementary school? Seriously like he said learn from your own mistakes if your not sure what your doing SEARCH.....a million people have done this swap all the info is here just find it.
Hybridguitarist
Oct 16, 2016 06:53 AM
Teggerson
Nov 25, 2011 12:08 PM
80 dolla crx hf
Nov 27, 2008 05:24 AM
matsgsr
Feb 6, 2007 12:35 PM
advanced3degrees
May 11, 2003 01:45 PM
