Need to know where the stock 2000 gsr wiring harness plugs into and obd1 motor n obd2
Need to know where the stock 2000 gsr wiring harness plugs into?
From the oil pressure to the tps and map etc all the plugs and where they go with pics.
obd1 motor n obd2
I have a b17 motor converted to obd0 now i am converting it to obd 1 or 2? (not sure yet)
I have a obd 1 motor that was converted to obd0 and now i am converting it to obd1 or 2? to run a obd 1 ecu while using the obd2 parts like dizzy, alt, and wiring harness
So far i have converted the alt and am planing on just leaveing the cas sensor and a few other ones unpluged, since i am running obd1 ecu.
I am using a 2000 gsr harness as i dont wanna hack it up nor find another since the car is 2000 as well
Anyone can help me on this?
anyone know if a 4 wire o2 off a 94 cx hatch will work in a 2000 gsr? Should as its plug and play on most other hondas
obd1 motor n obd2
this is how obd0 map sensors are.
http://www.ff-squad.com/tech/sensors/map.firewall.jpg
I think you should get a newer throttle body that has the map and tps both on it like this. http://www.ff-squad.com/tech/sensors/tb.sensors.jpg
oil pressure http://www.ff-squad.com/tech/sensors/oilpressure.jpg
And about the 94 CX 4 wire o2 im not sure since my 95 cx has a 1 wire o2?
i am gonna use a obd 1 map sensor and run it like that with the hose to the tb since the wiring is the same etc.
not sure about the rest of the diagram for the wiring harness
wow if I'm not mistaking the question is your wanting to run to use
obd1 motor
obd2 wiring harness
obd2 ecu
so the question is how to convert to obd2?
obd1 motor
obd2 wiring harness
obd2 ecu
http://rywire.com/store/faqdesk_info...6e410182f6c602
hope that helps. im kinda confused on what u need to know?
B18PwdCivic
Northeast (Sales)
16
Mar 28, 2008 02:37 PM
