who uses EGT gauges?
Old Oct 23, 2009 | 04:20 PM
Will_H's Avatar
Default who uses EGT gauges?
Who uses them and what temp should turbo applications be at? Do you have probes on each runner or just one?
Old Oct 23, 2009 | 04:59 PM
tepid1's Avatar
Default Re: who uses EGT gauges?
Each runner and it depends on fuel, timing etc....
Garcia-Racing's Avatar
We use them, temps are from about 800-1200 up top. We monitor each runner.
Old Oct 23, 2009 | 05:06 PM
rota92
Guest
Posts: n/a
Each runner, only because it's going to look like I know what I'm doing.
Old Oct 23, 2009 | 05:23 PM
Will_H's Avatar
so you would need 4 gauges then?
Old Oct 23, 2009 | 05:26 PM
miller's Avatar
EGT's are a great tool but you have to take them for what they are. They are more so to get your individual trims correct or to see if there is an issue with a certain cylinder.
If you want to talk egt's numbers I will tell that mine are pinned on my car as soon as I hit 3rd gear. 1745 is where they stop. I am upgrading to the 2200 sensor setup now.
Old Oct 23, 2009 | 05:51 PM
HR-1320's Avatar
Screw em. Never had them or wide bands. Read plugs.
Old Oct 23, 2009 | 06:03 PM
lou-tdi's Avatar
^^ ol' skool haha
Not planning on gauges, but logging individual EGT's for sure next year.
Miller: are you running individual wideband aswell?
Old Oct 23, 2009 | 09:34 PM
No gauges, we monitor them on racepak.
Old Oct 23, 2009 | 09:42 PM
tepid1's Avatar
Yeah.... gauges are not going to work that well.... you need to log that data.
Old Oct 24, 2009 | 03:21 AM
Will_H's Avatar
Is there are separate program to log them if im running hondata s300?
Old Oct 24, 2009 | 03:37 AM
miller's Avatar
racepak, the best datlogger out there imo...
Here is a quick link to the sportsman system...
http://racepak.com/Drag_Racing/Sportsman.php
and a link to the iq3 logging dash that can also be had..
http://racepak.com/Drag_Racing/IQ3.php
The best bang for the buck in the sportsman kit as this will give the guys who just need the basics more then enough channels to log.
Old Oct 24, 2009 | 03:45 AM
BIGTUNA's Avatar
I use this one, can get on sale for around $50 just add a sensor. Does min max and is back lit with big numbers so you can easily read it at night. Just add a sensor. When you live your life 13 sec at time you have plenty of time to look around and read gauges lol, well you would think that would be the case .
Old Oct 24, 2009 | 07:24 AM
Tjabo's Avatar
Interesting information Miller, and coincidentally fits what I was expecting. People think there is a limit to how high EGTs can go, but I think that isn't the case. Afterall, retarding your timing moves the temperature from the combustion chamber more to the exhaust, correct? Maybe not good for the turbo, but maybe less hard on the motor.
We've started to have this discussion on the MegaSquirt3 forum for planning the new code. While we've implemented an AFR safety cut if AFRs get higher than a user set limit by kPa, I don't feel that a similar strategy is applicable to EGTs. Got any feelings on that?
I do totally appreciate (and *think* I understand) the usefulness of EGTs from all cylinders for tuning individual cylinder fueling to correct distribution issues. I'm guessing in a turbo application individual runner AFR sensors wouldn't work well due to the pressure and temps involved in the runners. . .
Thanks in advance for any of your thoughts on this stuff! ! !
Old Oct 24, 2009 | 08:11 AM
sgnlab's Avatar
pm me pricing on both! Thanks Dude.
Old Oct 24, 2009 | 09:23 AM
nonvtecallmotor's Avatar
I data log all 4 egts with my PCS dashlogger. A few years ago I ran one in the down pipe with a hand held unit and it worked well but it only give hi/low egts on play back.
Old Oct 24, 2009 | 11:36 AM
onefstek's Avatar
I have a "Redline Gauges" 4 egt set up that comes with a gauge and 4 sensors. Also have the disk/program to datalog on your laptop.
Old Oct 24, 2009 | 03:19 PM
2fastGSR's Avatar
King of the One Liners
4 EGTS with an AEM Thermocoupler works pretty well . . .
stella_m_89121
Aug 11, 2017 07:01 PM
Ash J. Williams
Welding / Fabrication
Dec 2, 2012 09:17 AM
sshh
Sep 12, 2010 11:34 AM
Chillin94hatch
Jul 20, 2003 08:02 PM
Pengo
Jun 30, 2002 04:15 PM
