DA Chassis Harness HELP.
Old Oct 23, 2009 | 03:09 PM
B18IntegraLS's Avatar
Reject Pimp
Default DA Chassis Harness HELP.
I have a 91 Integra LS 5speed...and I need a new chassis harness, is it different than the 90? I heard it was I heard it doesnt matter does anyone know?!
Old Oct 23, 2009 | 03:37 PM
projectTeG's Avatar
Default Re: DA Chassis Harness HELP.
no,
Old Oct 23, 2009 | 03:54 PM
xravenwingsx's Avatar
I wouldn't think that it'd be too different, if at all
Old Oct 23, 2009 | 09:40 PM
earfejj's Avatar
doesnt matter 90 and 91 same.
Old Oct 24, 2009 | 08:15 AM
superls92's Avatar
Yeah there difference, the wiring going from the fuse box under the dash to the rear lights,fuel pump, etc. has some wiring diffeences. like the way the grounds are run and a few other differences, also it the main harness and the rear wiring harness have an extra plug that the 90 does not, it's a single wire plug that is also on the 92-93.
I actually just bought a 90 from someone and the wiring inside was fugged up, so I redid all the wiring by taking it from a 91 that's how I realized that the there was a wiring difference. If you get all the wiring from the same car you should be alright. If I had pics I would show you.
Old Oct 26, 2009 | 08:38 AM
Reject Pimp
I need help/knowledge installing one of these chassis harnesses on my 91 DA, can some one help?
Old Oct 26, 2009 | 01:12 PM
541DB1's Avatar
I'm almost positive that the 90-91 are the same, the 92-93 however, are different.
Edit: 2 posts before me (superls92) has hands on experience with said wiring, don't listen to me lol.
Old Oct 26, 2009 | 03:01 PM
Rajin's Avatar
90-91's are the same....regardless, same OBD same everything.
If it had extra wiring on his new harness, its probably because it needed to be there in the first place.
toxictom
Mar 15, 2018 04:08 AM
lazyboy
Dec 22, 2005 10:37 AM
slidewayseng.
Feb 17, 2005 11:46 AM
