another car won't start thread...lol...
Old Oct 22, 2009 | 08:53 PM
pkolaboy's Avatar
Default Ignition switch bad or alternator???
hey everybody...
Ok I have read alot of threads and came down to some of the faults... I have a 92 prelude si with a jdm h22a... I removed the cruise ctrl, pwr steering, and egr and just relocated the batt. For awhile (started like 4 months ago) the car would take a couple of turns to final turn the car over at differant points of time. Today was the worst. I tried turning the engine over to start but nothing happens (the engine won't even turn over). It can't be the batt. because all the wires are secure and all grounds are secure (Acutally I have not checked the ground by the thermostat). The CEL came on for good (of course it came on at differant times due to egr removal) and I noticed when I would turn the key off and then just to ACC, the CEL would stay off until I either pushed in the clutch or tried turning the engine over. So I waited until the CEL was off and quickly tried to start it and it did lol. Also my tach is going crazy, it would go to like 2,000 rpms and just drop and stay at 0 then rise up to what ever rpm...
I think my Main Relay is bad but am not sure. I'm just seeing if anybody has had a "similiar" prob. like this. If so, please feel free to through in your .02 or personal problems of past.
EDIT: I have checked everything from the grounds, replaced main relay, all connections are good..I replaced my radiator because it was sorta spraying everywhere and I think some coolant got on my alternator... could this be the problem?
Old Oct 23, 2009 | 09:45 PM
pkolaboy's Avatar
Default Re: another car won't start thread...lol...
Really ???
Old Nov 1, 2009 | 12:08 PM
pkolaboy's Avatar
Come on guys, I really need help... Bump for new info....
Old Nov 13, 2009 | 04:33 PM
pkolaboy's Avatar
i know the starter takes 12vdc for the relay to open... I checked the voltage and theres 11.65 vdc getting through... I didn't know if the +or- .5vdc applied for this... will the relay in the started not open if there is 11.65 vdc applied???
Old Nov 13, 2009 | 04:59 PM
minilogoguy18's Avatar
You said you're getting a CEL, have you even checked to see what code your throwing?
Old Nov 13, 2009 | 06:27 PM
pkolaboy's Avatar
the cel was when I cleaned the thermostat ground and forgot to ground the vtec oil pressure wire back...
Old Nov 14, 2009 | 09:54 AM
pkolaboy's Avatar
anybody??? I miss my car!
Old Nov 14, 2009 | 05:47 PM
Acidcrakker's Avatar
lol, today i started my prelude super ghetto. I turned the car to on position, than went under the hood and jumped the starter solenoid with a +12v wire, lol.
Old Nov 14, 2009 | 10:34 PM
pkolaboy's Avatar
lol yea i tried that... and my starter did not start... so I went and got a new one... and bam it works...
93WhiteHatch
15
Mar 15, 2011 05:11 AM
2LGSR
Nov 18, 2010 05:16 PM
drew10
Jul 16, 2010 04:01 PM
jdm22vtec
Apr 15, 2004 06:23 AM
serious
Sep 27, 2002 12:06 PM
