1995 ITR cluster????
Old Oct 22, 2009 | 07:27 PM
CaRb0y's Avatar
Default 1995 ITR cluster????
Alright i got a 1995 cluster type r but ii see that many don't have this cluster for sale or any info about it. I need to do a cluster swap but i can't find any info about this cluster anyone know what's up with this 95 cluster ????????, its the JDM one by the way..
Old Oct 22, 2009 | 07:31 PM
itr#1334's Avatar
Default Re: 1995 ITR cluster????
Pics?
Old Oct 22, 2009 | 09:47 PM
xiapher's Avatar
well if im not wrong itr's are 96 and up soo that could be ur first issue
Old Oct 22, 2009 | 10:13 PM
20-EM2-05's Avatar
Japan had a Honda Integra Type R.
He did say it was the JDM one.
Old Oct 22, 2009 | 10:17 PM
xiapher's Avatar
lol yes i know i deal with jdm motors everyday im saying that the Honda integra type r wasn't made till 96 so 95 there isnt one to my knowledge
tipe R's Avatar
they didn't make itr's in 95, it came out in japan in 96, and the US in 97
Old Oct 22, 2009 | 10:18 PM
tipe R's Avatar
what kind of info are you looking for?
Old Oct 22, 2009 | 10:54 PM
Klasse's Avatar
There are a few '95 ITRs. Pretty sure the 95/96/97 are all the same though.
Old Oct 23, 2009 | 04:36 AM
MiraiZ's Avatar
do your homework. ITR's debuted in 1995 in Japan.
Old Oct 23, 2009 | 06:39 AM
94rs-turbo's Avatar
yes sir late 95 itr's where around
Old Oct 23, 2009 | 07:32 AM
srt4mike's Avatar
I believe you mean "were"
Old Oct 23, 2009 | 08:03 AM
Tyrant_007's Avatar
August 1995 if I'm not mistaken. Almost half of '95 they were available. Still referred to as 96-spec, so that may be where the confusion is coming from.
Old Oct 23, 2009 | 09:06 AM
tipe R's Avatar
sorry, i didn't think about the fact that new cars are released 4 months before the year of its debute, but it is still a 96 type R.
Old Oct 23, 2009 | 01:06 PM
CaRb0y's Avatar
Ok people here are so pics, and tell me what year it is. its JDM i know someone knows about this cluster and i hear that the type R started in 1995
Check this link out http://www.j-garage.com/honda/integra/dc2.htm if you don't belive
Old Oct 23, 2009 | 02:28 PM
CWTegRNo.160's Avatar
I can't tell you anything about the cluster but wow. only 37,643km. how many miles is that? Hopefully ITR theft didn't start in 1996.
Old Oct 23, 2009 | 10:00 PM
xiapher's Avatar
yea deff a real jdm cluster whats wrong with it
Old Oct 24, 2009 | 08:19 PM
CaRb0y's Avatar
yea if you see in the 96 spec it has a catalytic converter icon on the upper left and my doesn't and the 96 spec on the upper right their is a seat belt and door ajar icons. my only has the door ajar and a ABS icon. plus mine has the seat belt icon at the right bottom.But it looks like the 98 spec one of the two i found on the net... But why does it say a 95 ??????
Old Oct 24, 2009 | 10:11 PM
MiraiZ's Avatar
Still incorrect. They were considered 1995 ITR's, but since the 96's had identical specs, they were all called 96 specs. Just like the 97's which were also called 96 specs (as opposed to 97 spec). A 96 spec wasn't called a 96 spec, until the 98 specs were introduced.
In all fairness, 96 specs should have been called 95 specs.
Old Oct 25, 2009 | 09:34 AM
CaRb0y's Avatar
yea, But wouldn't the wiring be different??? of the clusters
Old Oct 25, 2009 | 03:58 PM
MiraiZ's Avatar
95=96
98+ all the same
if you have a 98+ Integra and a 95-97 cluster, you can simply swap the green circuit film on the back and it will work. However some of the indicators will be a bit off.
Old Oct 25, 2009 | 05:39 PM
CaRb0y's Avatar
WHAT swap the green ciruit film, Hell NA why don't you tell me to break it instead!
Old Oct 25, 2009 | 06:43 PM
SoTexDC2's Avatar
Swapping the "Green Film" is common practice to make clusters work between model years.
What exactly do you think is going to break?
Old Oct 25, 2009 | 07:05 PM
MiraiZ's Avatar
All you need is a Philips screw driver and it takes less than 20 minutes to do...of course, you would know this if you searched.
Old Oct 25, 2009 | 07:07 PM
MiraiZ's Avatar
By the way, I bought a 96 cluster ans swapped the film with my OEM cluster and it works perfectly.
Old Oct 25, 2009 | 09:09 PM
Klasse's Avatar
Not having a cat light is really weird - surely all years came with a cat.
