PA ******looking to trade for a running car********
I would like to trade my whole entire setup for a running eg hatch, ek hatch,coupe,integra with no rust and one color. This is a good opportunity for someone who wants to do a winter build or has another shell ready to be swapped .
407-873-5677 aim sp33ddemon19
I am located in Harrisburg Pennsylvania
my fully built lsvtec longblock with all reciepts and papers
******vin code 13198*******
were gonna go from the head to the block starting with
b16 head with
.5mm over sized ferrera valves
ferrera springs
ferrera retainers
84mm cometic head gasket
arp head studs
type-r intake manifold
polished aem high flow fuel rail
gsr cams
skunk2 5 bolt cam gears ''red''
ls block b18a1
84mm aebs sleeves and o ringed
cp 9: 2:1 pistons
crower rods crower rod bolts
arp mains it is fully studded throughout the whole bottom end
king bearings
z10 girdle
act 12.5 lb flyweel
tapped oil pan
balanced
blueprinted
micropolished crank
act hd pressure plate
3 puck sprung clutch
i will also include all brand new gaskets i have already put a new rear main seal in right now it has 0 miles as well as new oil pan gasket, and new valve cover gasket,and new tube seals all brand new in boxes and bags
this motor is good to 600hp plus with proper tuning and fuel setup who ever gets this will be happy also I have every single receipt for this motor build witch I will give to the buyer with the motor all parts were bought brand new.
blox ac, ps friendly log manifold
2 bolt tial 44mm wg polished
dump tube
hks ssq bov
greddy front mount
ebay turbo
oil feed line
ic piping
greddy turbo timer with all wring
walbro 255
rc 750 saturated injectors
chipped and ziff socketed p06 with a chip
auto meter air fuel gauge
auto meter water temp gauge
autometer tachometer
msd blaster coil
msd distributer cap
msd plug wire
i will also include a custom built sc61 turbo with a 67 mm compressor wheel that neesd to be rebuilt...i got a price on a borg warner rebuild kit for this turbo costs 50 bucks..
I have a lot of money in this so I dont see a problem in asking for a running car that looks decent with a few simple add ons.
thanks for looking bump if you look
b16 head with
ferrera springs
ferrera retainers
arp head studs
gsr cams
ls block b18a1
cp 9: 2:1 pistons
king bearings
z10 girdle
act 12.5 lb flyweel
tapped oil pan
balanced
blueprinted
micropolished crank
dump tube
hks ssq bov
greddy front mount
ebay turbo
oil feed line
ic piping
walbro 255
msd blaster coil
msd distributer cap
msd plug wire
i am pretty open to cars i just want something nice im not looking for a beater or a car that needs paint and body work if its clean and and has a few typical mods maybe rims, hids, suspension, or whatever like i said im pretty open.
