Transmission & Drivetrain Gearboxes, Differentials, Clutches
2nd gear lockout on downshift???
Old Oct 22, 2009 | 06:51 PM
brokeHonda's Avatar
Default 2nd gear lockout on downshift???
Hey,
'00 ITR tranny has me locked out on downshift to second from third. Everything else is fine, no grinds and other gears work through up and downshifts. I can downshift to 2nd if at a complete standstill or slow roll with lots of double-clutching. Thoughts were the synchro for 2nd but there is absolutely no grinding just lockout! Gear selector? I removed the shift fork springs and everything looks good. I'm at a point where nothing is searchable for answers. Thanks ahead of time.
Old Oct 22, 2009 | 07:09 PM
Aquafina's Avatar
Default Re: 2nd gear lockout on downshift???
Replace the detent bolt washers with new washers then try again.
If that doesn't work then it is likely something with the 1/2 sleeve set.
Old Oct 23, 2009 | 07:52 AM
brokeHonda's Avatar
Are the crush washers specific to Honda via dealer or available through retailer?
Old Oct 23, 2009 | 10:04 AM
Aquafina's Avatar
I've never tried to use anything other than the OEM Honda washers so I can't say for sure.
Old Feb 27, 2010 | 07:40 AM
brokeHonda's Avatar
Alright, replaced the 1/2 sleeve set, 3/4 sleeve set, 2nd gear fork, and detent washers. I can select 2nd but getting grinding now. Everything is installed correct. No grinds for 3/4. I shouldn't be getting any grinds for 2nd!! Very confused now. Could it be the change holder??
Old Feb 27, 2010 | 07:59 AM
projectTeG's Avatar
you change the syncros and and check the springs?
Old Feb 27, 2010 | 08:16 AM
brokeHonda's Avatar
Yep, replaced the synchros!
Are you referring to #10 spring. If so, no didn't get checked.
Old Feb 27, 2010 | 08:18 AM
brokeHonda's Avatar
Now that you mention it that spring would be responsible for driving the fork/sleeve up into place. If it was weak it would not be able to get the sleeve into place and potentially cause a grind??
Old Feb 27, 2010 | 08:34 AM
projectTeG's Avatar
i was talking bout the syncro springs that go on the back side of the syncro to allow the slider to engage the syncro
Old Feb 27, 2010 | 08:48 AM
brokeHonda's Avatar
Yep replaced the entire sleeve set. #7 as a whole
CubbyChowder
Jun 1, 2010 04:44 PM
94_teggy_rs
Jan 1, 2008 09:20 PM
audiimportech
Jul 13, 2007 09:13 AM
n-line4
Oct 11, 2005 03:34 AM
drewwatts23
Jun 13, 2004 05:54 PM
