best bang for buck car speaker for integra
well i was planning to get car speakers for my car as soon as my financial situation is settled. so i decided to start looking around. does anyone have any suggestions?
i was planning to upgrade the stereo and speakers only and not buy an amp or sub.
edzy will say otherwise, but unless you already have an aftermarket hu, then I would suggest getting one instead of speakers (unless yours are blown).
An aftermarket hu will make the most difference.
Look into clarion or alpine.
I have a clarion in my integra and you wouldn't believe the difference it made over the stock unit with only the stock speakers.
What is your budget?
If you plan on not amping your speakers, you need to get a set of speakers w/ the closest RMS and the RMS output of the headunit. Also, you should look for speakers that are close to 90 hz (i think) for the most efficiency.
My budget on the speakers are like $100 =X 150 max. And I might think about getting an AMP since my friend's uncle has one laying around. And Des answer the PMs i sent ya!
Phoenix gold rsd http://www.woofersetc.com/p6952/RSD6...ker-System.htm
matched with
http://www.woofersetc.com/p6841/DSC2...-Amplifier.htm
couple bucks over budget.
matched with
What HU is in the car now?
Is your Integra a hatch?
As has been mentioned, as long as the speakers are not blown and you still have a stock HU, replacing the stock HU with an aftermarket one will make a much bigger diff. the replacing the stock speakers, no matter how much you spend on speakers.
If you still have the stock, [dual cone] speaker in the car replacing them with a 2way speaker will increase high frequency response a little, [noticeably] but that's about it, if you still have the stock HU an aftermarket speaker may actually sound worse then the stock one because of a loss in efficiency of the speaker.
Whatever you decide to do the stock speaker is a "standard" 6.5" speaker with a mounting depth of 2", do not confuse it with an over-sized 6.5" speaker or custom work will be needed to fit the speaker.
Also, do yourself a big favor, buy from an authorized dealer, local retail or online vendor, save yourself a lot of grief and do not buy from unauthorized "resellers" like... http://www.woofersetc.com/page/shopwithus.htm it will only cost you if you have a problem. 94
What speakers are in the car now?
I have a stock HU. Was planning on buying that too, any recommendations?
And yeah it's a coupe.
But yeah, I think speakers are blown, seeing when I turn the speakers up it gets kinda staticy.
You should replace the hu first and then the speakers afterward.
I have the stock speakers in my teg, with a clarion hu and it sounds kick ***.
You should look at clarion or alpine as far as hus go. Note that the older model clarions are much better than this year's models as far as single din goes.
MiKeEH, get the HU first, Alpine or a Panasonic if you on a budget 94
matched with
matched with
What Head Unit do you guys recommend for me to get? I decided I'd work on that first. I would like an Ipod Connector with it also!
