who can rebuild a b16?
i have 99 si... b16 motor motor has miss(bad valve) i just wanting it rebuilt block and head (all factory internals) ive been quoted $1100 on a full rebuild is there anyone cheaper interested?
1100 parts included he does
new cam bearings
new rod bearings
new pistons
new rings
new main bearing
new full gasket set
new freeze plugs
new lifters
timing belt
new oil pump
resurface head
new valve seals
honing block
cut valves
painted block and oil pan
new oil filter
new plugs
house of motors $1100 installed
new cam bearings
new rod bearings
new pistons
new rings
new main bearing
new full gasket set
new freeze plugs
new lifters
timing belt
new oil pump
resurface head
new valve seals
honing block
cut valves
new oil filter
new plugs
never heard of cam bearings before on a honda and b16 doesn't have lifters. sounds to me that the price is unbelievably to good to be true. wow. but I'm sure they won't use honda oem parts. usually a very inexpensive engine rebuild kit. remember, u get what u pay for. if I were to rebuild it, I would put new rings, rod bearings, hone block, replace only the bad valve, resurface head, all necessary gaskets, of course the t belt. and I think that's all I would do. this is being realistic too. and these parts will be from honda too. (I work for honda)
ccjb100
Aug 20, 2012 08:25 AM
