96 accord steering/break problem
Old Oct 22, 2009 | 09:44 AM
Acc0rd96's Avatar
Icon3 96 accord steering/break problem
Lately, something wierd has been happening with my steering. Whenever i hit the break moderately hard, my steering wheel and car goes to the right. I have a few ideas what could be wrong like master cylinder,rotors, calipers or allignment.. I got an allignment about a month ago along with a wheel balancing and i just changed my calipers and the problem still occurs. Any suggestions or ideas on the problem?? thanks
Old Oct 22, 2009 | 09:16 PM
PilotOnDubs's Avatar
Default Re: 96 accord steering/break problem
damn, thats a tough one...i was going to say, calipers, but you said you changed them...
the only thing i can think of at the moment, is a possible "clogged" brake line...maybe one caliper is getting more pressure than the other causing a pull while you brake...
how often or when was the last time you had your brake system/ fluid flushed...
if you havent, "i hope you did, when you replaced those calipers"...
you might want to take it to a shop that performs a "pressure brake flush" w/ a machine or a pressurized tank (a special honda tool) instead of manually bleeding the brakes so that they can get all the crap out of the master cylinder and lines...
Old Oct 23, 2009 | 05:09 AM
Acc0rd96's Avatar
ya i changed the calipers but they are kind of shitty because i got them from autozone.. and after a few good rain storms.. they were just covered with rust. So it seems like the calipers i bought were crappier than the ones i originally had..
yeahh i flushed my system a few times and made sure to get all the air out and stuff
would changing the brake lines do any good?
Old Oct 23, 2009 | 12:20 PM
P_Adams's Avatar
Are the rear brakes drum or disc?
Does it pull hard in one direction; or is it more like it just wants to go that direction?
Have you had the tie rod ends checked for slop?
P
Old Oct 23, 2009 | 04:20 PM
HonBeer's Avatar
Break? Its spelled brakes
Old Oct 23, 2009 | 04:32 PM
P_Adams's Avatar
Is this where I'm supposed to interject:
Oh, "come on... give him a brake"
P
Old Oct 24, 2009 | 07:57 AM
Acc0rd96's Avatar
yaa sorry for the spelling.. i was in a hurry to put this up..
the rear brakes are drums
well.. its basically both, when i start to break, the wheel goes right and the cars goes right as well. Sometimes it's not too noticeable and does it only a little but other times, the wheel just flies to the right..
I think i've concluded that the right side caliper brakes before the left one so it goes to the right.. I'm just not sure what to do now
Old Oct 24, 2009 | 09:42 AM
P_Adams's Avatar
I would suggest 2 things:
I would check that the LEFT caliper is not sticking on it's sliders (it would cause the caliper to not apply as hard as the cousin to the right, thus the pull)
and
I would check that you haven't developed a brake fluid leak in one of the rear brakes. (It would cause on of the rear brakes to 'grab' when applied and would cause a pull condition)
P
Old Oct 25, 2009 | 07:14 PM
Acc0rd96's Avatar
thanks for all the help. i really appreciate it.
I actually got a brake check up by some people and they said that there was something wrong with my passenger side break hose. I guess the fluid stays in the caliper so its always kind of braking and once the rotor gets hot from all the friction, it causes the car to vibrate (which always happens after a 45 min drive) and the car to pull to the right. They also suggested to get new rotors..
WELL... so far ive only changed the 2 brake hoses and i will see how the drive is tomorrow and if its still pulling and all, ill change the rotors
Old Oct 25, 2009 | 07:22 PM
nus_dogg's Avatar
There might be something with the brake line that's clogged up, but that would cause a brake drag though.
What I'm thinking though, is that when you brake and it pulls to the right, then that means the left caliper must've been bad? since its not grabbing like the right caliper should. Unless you did replace the left caliper too.
Old Oct 26, 2009 | 05:53 AM
Acc0rd96's Avatar
ya thats what i think too but i just drove for about an hour and it still pulls but not as much..
ya i changed both calipers
Old Oct 26, 2009 | 11:44 AM
HonBeer's Avatar
Check your brake hoses. They may be internly blocked causing a check valve effect(fluid goes one way and not the other).
Old Oct 26, 2009 | 01:59 PM
Acc0rd96's Avatar
yah.. thats exactly what a mechanic told me.. so i changed both brake hoses and it still pulls..
Old Oct 26, 2009 | 02:23 PM
cstone's Avatar
possibly a hard break line clogged (the steel ones). a pressurized flush could help
Old Oct 27, 2009 | 12:58 AM
AuroraHonda's Avatar
Post Re: 96 accord steering/break problem
Maybe a Ball Joint? Or bad Control Arm?
Old Oct 27, 2009 | 04:23 AM
Acc0rd96's Avatar
i put in new upper control arms with new ball joints a couple of months ago...
Old Oct 27, 2009 | 05:30 AM
P_Adams's Avatar
Where did you procure the calipers from?
P
Old Oct 27, 2009 | 01:23 PM
Acc0rd96's Avatar
autozone... they work but they already have a rusty layer on them
Eee Kayyy
Apr 16, 2019 09:58 PM
gqstatus05
Dec 12, 2007 12:40 PM
V-Thang
May 18, 2004 04:48 PM
RiCE On IcE 2
Dec 20, 2002 12:43 PM
