help with my hose 94 f22b1...please
Old Oct 22, 2009 | 07:20 AM
njkill's Avatar
Default help with my hose 94 f22b1...please
im doing a f22b1 swop in to my 90 prelude.
the help identifying the smaller hoses on the motor
im not a mech.
like are they coolent or oil?
pics
aticals
rightups whatever thanks
also if you have any idea whare the vacuum lines on my vcbox should go on the motor.
and msd blaster kit will that work on my engine.
thanks for your help
chuck
Old Oct 22, 2009 | 07:38 AM
njkill's Avatar
Default Re: help with my hose 94 f22b1...please
and anouther thing
ac
dose the ac pump for that motor bolt on derectly or is thair a braket?
thanks
Old Oct 22, 2009 | 11:08 AM
bseriescrxsi's Avatar
well first off you would have to provide pics of the line you asre talkin about...we arent mind readers and there are alot of lines on every honda...second...maybe you shouldve done a little more research on this swap before jumpoiung into it as you mentioned your not a mechanic
Old Oct 22, 2009 | 03:10 PM
njkill's Avatar
im realy getting tired of u fairys
get off thair dick.
thares only 2 in back near the mount and 2 or three on the trany side of the engine up by the intake that are not vacuum
is it diffrent on other f22b1vtec engines no it isent
and only 5 comming from my vc box
if you cant hep then dont keep your mouth shut
i did my reserch ***
im not a mech. so i need help with this
its ppl like you that make me not donate **** to theas foums
Old Oct 22, 2009 | 04:14 PM
jdmwannabee's Avatar
get off thair dick.
the two small hoses, on the rear cross member, near the rear mount are for your vss
any actual hoses would be for coolant, there's the heater core, upper, n lower radiator hoses.
there's a metal/ rubber line that goes from the back to the front that would be your clutch line.
murderedrsx
Feb 2, 2010 10:06 PM
h22_crx
May 11, 2008 06:22 PM
NoVALude
Apr 10, 2006 09:26 AM
baonest1
Jan 14, 2003 06:48 PM
