P06 / P72 ECU compatability (quick)
Old Oct 21, 2009 | 09:48 PM
VegasInvasion's Avatar
I'm Huge In Japan
Icon2 P06 / P72 ECU compatability (quick)
Title explains it. I searched, there's no clear answer.
I just want to use a P06 ECU in a GSR to see if it cures the limp mode.
I know there's no Vtec & IAB support, that's fine, I'm more concerned about the harness. Does it need to be rewired, or am I good to plug & chug?
Old Oct 22, 2009 | 05:35 AM
gilcontr's Avatar
Default Re: P06 / P72 ECU compatability (quick)
it should plug in and work as long as they are both obd1. I thought i heard of an obd2 p72 ecu but that might be BS. are you in limp mode due to the ecu? weird.
Old Oct 22, 2009 | 11:39 AM
thewrai6th's Avatar
What year and are they both either obd1? Isn't the P06 a civic ECU? I would not try to run that on a B18. The fuel and timing maps are not going to be correct. Does the P72 give any codes?
Old Oct 22, 2009 | 03:25 PM
SpEeDyX's Avatar
lmao yea theres obd2 p72's i know cause i run one
Old Oct 22, 2009 | 04:01 PM
gilcontr's Avatar
seems like he just wants to test it to see what will happen. the p06 should be ok for that
there ya go! make sure your ecu is an obd1 p72
Old Oct 23, 2009 | 11:35 AM
I'm Huge In Japan
Thewrai6th, the only way I'd run a stock P06 is if I had a stock DX to go with it, heheh
Yeah code 3. Traced the MAP lines, connections & readings are good (power signal is a little low, 4.5v), but I don't think the ECU is translating. I bypassed the chip, although I set the stock basemap on it.
I'll give this a shot, thanks errbody
Pimpsherm2009
Jan 13, 2010 06:05 PM
ZC DOHC CRX
Mar 20, 2009 04:46 PM
jimmy o.
12
Sep 2, 2008 04:58 PM
girlsaremean
Nov 6, 2006 06:25 PM
