Mini - Me. no joke How hard to do right.
Old Aug 29, 2002 | 08:01 PM
89 CRX SI's Avatar
Default Mini - Me. no joke How hard to do right.
I can get a d16z6 head loaded with parts for really really cheap. how hard is this to put on my d16a6 block. my engine bay is wired as the Si setup.
the head has head gasket and head bolts too !
How much work will this be? I would use an RPM activated switch for VTEC. and run a turbo later. to compensate the lost fuel in VTEc i will use a V-AFC. I can get a V-AFC in the winter.
How bad will it run without the V-AFC????
thx guyys.
and is it noticeable fgaster?
Old Aug 29, 2002 | 11:25 PM
havok hybrid's Avatar
Default Re: Mini - Me. no joke How hard to do right. (89 CRX SI)
i have had a d16a6 with a 92 vtec head on it.. it is really easy to do.. u have to pull the oil jet out of the block.. there is one in the vtec and not in the non vtec head. then u have to run a 92-95 timing belt. i forgot what u have to do for the timing.. and the distrubtor will not just bolt up.. u will have to mod.. easy . there many be a lil more.. i also ran that motor on 6 psi but i think it was the compression that blew it.. mini-me is like 10.4 to 1 .. let me know
Old Aug 30, 2002 | 06:37 AM
USDM 4G VTEC's Avatar
its not hard at all.. bolts up , u only need to change the oil jet like the other bro said
well if u use the 5G FPR u will be running rich and that will compensate for fuel problems on VTEC.... it will not run bad without the VAFC, but ti will not run 100% perfect.....and yes its more noticeable faster. specially it feesl more torquey.....
Old Aug 30, 2002 | 06:52 AM
dpo95si's Avatar
Default Re: Mini - Me. no joke How hard to do right. (JDM EF9)
do you guys know a web page to show the wiring that needs to be done?
Old Aug 30, 2002 | 06:57 AM
Default Re: Mini - Me. no joke How hard to do right. (dpo95si)
see my sig?? go and read........ also http://www.hybrid-k.com search the archives and fint the ZC to DX wiring conversion..... thats basically it.... but dont reverse the TPS
Old Aug 31, 2002 | 09:49 AM
Stupid Ass's Avatar
Just make sure you spend a little time tuning it to get the right A/F ratio and make sure you tighten the head down properly... and it should all be fine
Old Sep 1, 2002 | 06:57 PM
89 CRX SI's Avatar
Default Re: Mini - Me. no joke How hard to do right. (SOHC NoTEC)
the oil jet thing please explain. i dont have one with the new head.
today i removed everything attached to the head but the head wont come off the block??? i unbolted the headbolt and yanked for all i got.
so i need to buy a 92 civic 1.6 l timing belt and a oil jet for the block for a 92 civic.
will the cam gear off my d16a6 work???
oh yeah can i reuse the head gasket for the SOHC VTEC head cause it isnt seperated and in great condition i think it was recently replaced on the d16z6 motor
THX guys
Radim
Sep 1, 2008 09:15 PM
mck26
Oct 23, 2006 07:07 AM
egcivic611
Feb 13, 2006 10:37 AM
Replica
Jan 23, 2003 12:49 PM
grncivic91
May 27, 2002 11:36 AM
