ITB thoughts?
Alright guys so I've been looking around on the forums online and stuff and i can't find any real info on ITB's for our cars. I know they dont have much of a purpose on stock engine and yes I intend to build my engine (my rings are going out so while I have it apart im going to build it) and no this isnt my DD. I've seen it done before but not often. Any help, tech, links or opinion are greatly appreciated.
yeah...i was gonna throw OBX ITBs on my lude, but decided not to cus it was going to be my daily driver, but if ur not gona daily drive ur, u should go for it mang, u'll get great throtle responce
Yeah but I've also heard bad things about OBX as a brand.
there seems to be a good lookin ITB and they seem to carry them for a lot of engines.
so maybe they good?
http://twminduction.com/ThrottleBody...leBody-FR.html
but i would like to make a track car and ive always head ITB's had really good throttle response but are a bitch to tune.
I'd like to hear something about this from the guys that have been in the game for a long time and actually SEEN this on a prelude.
so maybe they good?
good deal. I'll definitely be using them then IF I decide to actually go the route over going boost.
I like the idea of ITB's because you dont see it a lot but Im not sure about the dependability or the actual gains you get from it.
98vtec was banned and edited over a lot of his write-ups.
and yeah im gonna rebuild it with oversized piston sor maybe a stroker kit and jun cams and stuff.?
iunno im just wanting to figure how it would work or howd be for power before i drop 2800 bucks on it.
depends i am in a predicament at the moment.
i am along the following thought processes.
1) i have a cam that is optimized for midrange so an IM like skunk / euro give me more top end.
2) choose a cam built for top end, and then get ITB's to beef up the midrange.
i guess it depends on what you want to use the car for.
http://jhpusa.com/store/pc/viewPrd.a...idproduct=3726
just ran across those today...just looking around. i've heard that itb's sound wicked. no personal experience.
i did get some twm but they would not fit without modifying the ABS unit, and if you want the CF cover for them it definately won't fit with ABS.
Thats also part of the problem
Yeah well on the issue with taking out my ABS thats something i was planning on doing anyway.
I mean I've already relocated the fuse box, relocated the battery, took out C/C and all of the A/C. P/S and ABS are next on the list.
And of course Im going to want the CF one haha.
But if I run ITB's I might spray it but i doubt it because ill have to run direct port into the head right?
But I'm just wondering what kind of number would I be looking at with ITB's and forged pistons, more aggressive cams, cams gears, H beam rods, crankshaft,bored over, head work, ETC.
and then if im not satisfied with that maybe some spray?
Well if I do run this set up im not leaving the block stock buy any means.
I was looking at boreing it over to 89mm and running bulletproof sleeves with a stroker kit.
think that could handle the nitrous? haha
Jim
I used over 100lbs with a 100shot
Why are you so anxious to post bad info?
ITBs are all about throttle response......Nat from BTP just installed them with a 2whp gain[peak]
2 whp? peak?
you cant be serious.
was he built?
with what research I've done, you don't gain much on a stock block but you have a pretty good gain on a fully built engine.
was he built?
Natalie, yes, she has a built setup. You need to do much more research into the subject if you plan on doing it. There is alot of info out there not directly related to H motors that will benefit you.
Im not posting bad info your a hypocrite 1st you say a h22 cant handle 8psi safely but yet they can take 125 shot.I wud never do that to a stock h22 good bye to h22 mazx 75 shot safely.
Doesnt mean that you have to listen to what he says either.
Save the pissing contests for something better
On a more serious note, ITBs like everything can be tuned, longer runners for peak power or shorter for mid-range, switching up fuel injector locations etc. Two things are pretty much certain with ITBs: Your throttle response will improve and you'll have one more tool for maximizing your area under the curve.
