1989 Crx Si
Seeing whats out there, if I can't find what I want, I'm gonna keep it for a winter project.
Looking for DB1's, EG's, EF's, 94-95 Integras. NO ek's.
No swaps, just stock cars. Trades only.
Clean title
218xxx on the body and head
115k on the z6 block
100k on the trans (shifts good,a little hard to get into first and grinds reverse)
Ghetto intake
Half-size radiatior, got it new in February.
Fresh valve cover gasket
Fresh passenger axle
Fresh upper ball joints
Year old battery with 2 year warranty (relocated to the back)
Newer brake booster
Fresh header back exhaust, 2inches with a test pipe, not loud at all.
Body is pretty clean for its age, there was some work done on the driver quarter...
A new panel was welded in but, previous owner failed on prepping it correctly.
Also, there is just under the gas door (see pictures) and in the door sills.
Fresh 90-91 tails
Interior is also clean, the driver seat is the only ugly part, a slight tear in the bolster but, we all know how common that is.
I have all the carpet and misc things for the rear
Jensen cd player, works great
Heat blows good
A/C was removed by previous owner
GSR shift ****, DC short throw.
Sitting on steelies with newer tires all around 2 Ziex,1 Goodyear and 1 BFgoodrich
Tein SS coilovers,siezed spanners in the rear.
Brand new Blox LCA's with fresh bolts.
Bads:
Trans (as stated above)
Rust
Burns a little oil
Needs a speedo cable, working on that right now
Front bumper is gutted out
Sunroof stays cracked sometimes, doesn't leak! **
I'll have better pictures up at some point.
Clean title
Ghetto intake
Newer brake booster
Fresh 90-91 tails
Heat blows good
Bads:
Rust
Burns a little oil
Thanks guys, I think im just gonna keep it. The past 2 times I've put it up for trade or sale, I've gotten rediculous lowball offers (100,150- ~400) not even just on craigslist but, here and MWIR as well.
I'm just gonna keep it, see you bitches on the road coarse next season.
I have a 1991 EF DX all stock if you're interested...Needs some work like exhaust/axles and heater doesn't blow heat for some reason. Other then that, it has a strong engine and tight clutch. LMK if you're interested.
stevescivic
Aug 17, 2007 10:10 PM
