Unexplainable idle problem?
Old Oct 21, 2009 | 11:50 AM
vanderwiel's Avatar
New User
Default Unexplainable idle problem?
I drive a 1996 Civic LX with an automatic transmission. 1.6L.
The problem is when in drive or reverse it idles at a constant 2200 RPM
I neutral or park the RPMS go from 200 - 2200 repeatedly.
There is no check engine light on though.
A bit of background, the car always idled very low, and at times felt like it would stall, but never did.
Then I put it into a ditch and had to replace the radiator as a result. Ever since it has been running this way.
Anyone have any ideas?
Old Oct 21, 2009 | 01:07 PM
civic_r87111's Avatar
Default Re: Unexplainable idle problem?
Check that the coolant is properly blead and that all grounds r clean and tight.
RonJ@HT, check the ground on the thermostat housing especially
Has symptoms of a TPS out of alignment as well but I don't think that would be it unless u or the person b4 u has messed with or replaced the TB.
Old Oct 21, 2009 | 01:17 PM
imbest123's Avatar
iacv possibly needs cleaning
Old Oct 21, 2009 | 01:20 PM
Former User's Avatar
I agree.
This procedure may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
koko1589
19
Mar 23, 2012 05:36 PM
mark2583
Jan 31, 2007 02:42 PM
2000civicsi
10
Oct 26, 2005 04:05 PM
matt j
Jan 2, 2004 07:21 AM
stRtypR25
Jan 12, 2003 03:09 PM
