Unexplainable idle problem?
I drive a 1996 Civic LX with an automatic transmission. 1.6L.
The problem is when in drive or reverse it idles at a constant 2200 RPM
I neutral or park the RPMS go from 200 - 2200 repeatedly.
There is no check engine light on though.
A bit of background, the car always idled very low, and at times felt like it would stall, but never did.
Then I put it into a ditch and had to replace the radiator as a result. Ever since it has been running this way.
Anyone have any ideas?
Re: Unexplainable idle problem?
Check that the coolant is properly blead and that all grounds r clean and tight.
Has symptoms of a TPS out of alignment as well but I don't think that would be it unless u or the person b4 u has messed with or replaced the TB.
RonJ@HT, check the ground on the thermostat housing especially
2000civicsi
10
10-26-2005 04:05 PM
