water getting in the trunk area. Bottom cushion rear seats getting wet. Causes!?!?!
Old Oct 21, 2009 | 10:28 AM
type-GGSR's Avatar
Default water getting in the trunk area. Bottom cushion rear seats getting wet. Causes!?!?!
Whenever it rains, my trunk area where the spare tire sits seems to have a puddle. Also, my rear seats get wet (bottom cushion). i just want to know ALL the possibilities as to why this is happening.
much help appreciated.
Old Oct 21, 2009 | 10:41 AM
Gotppg?'s Avatar
Default Re: water getting in the trunk area. Bottom cushion rear seats getting wet. Causes!?!
Mine did the same thing so I just replaced the rubber on the hatch and prob went away.
Old Oct 21, 2009 | 10:42 AM
cbaber's Avatar
I just got my teg and have never really driven it, but when I was cleaning it out I noticed that the previous owner put towels in the trunk area to absorb water. Maybe this is a common problem with tegs?
Old Oct 21, 2009 | 10:45 AM
type-GGSR's Avatar
even if i were to do that, i dont see how the rear bottom cushion should be getting wet.
Anyone else have any ideas as to why this is happening?
Old Oct 21, 2009 | 10:52 AM
madmanshima's Avatar
do you have a sunroof? if you do check the drain hoses,that could be a possibility.
Old Oct 21, 2009 | 10:54 AM
type-GGSR's Avatar
Yes i do have a sunroof. Care to give me an idea as to where the drain hose is?
Old Oct 21, 2009 | 11:13 AM
your probably gonna have to take out the rear side panels and if you look behind the panels you will see the hoses.heres pics.
Old Oct 21, 2009 | 11:34 AM
bullitt042001's Avatar
I'm dealing with the same situation,I had replaced the sunroof drain hoses,the weather strip as well,I had removed all the hatch area panels and rear seats,since it has been raining like for two weeks in a row,I've notice the tail lights was the problem,I guess the taillights gaskets were bad,so I just picked them up from the dealership.
My seats were wet, even the front carpet was getting wet as well ,what I'm guessing is that all the water was getting trough the taillights,and was acumulating untill the point the spare tire area couldn't hold it and started running to the front.
Old Oct 21, 2009 | 12:07 PM
ohsojdmdc's Avatar
ran into this problem as well and it was the hatch weather stripping, thats my guess i also checked the sunroof drain hoses and that wasnt it, also had to replace the windshield weather stripping because it was leaking , guess after a couple years exposure to the elements they dry rot
Old Oct 21, 2009 | 12:08 PM
jomama's Avatar
you'll probably have to remove the headliner and panels, get in the car, and have a friend on the outside with the hose spray water on the outside of the car till you single out the area(s) where you have leaks
Old Oct 21, 2009 | 12:13 PM
Gotppg?'s Avatar
Water is coming out of the spare tire area when you brake. But try a few different things cause I've had leaks all over honda's before. Around the rubber in the doors leak sometimes also.
Old Oct 21, 2009 | 12:35 PM
type-GGSR's Avatar
thanks for all the replys guys! I guess ill tackle the headliner and side panels this weekend to see whats up. If that does not work, ill probably check the tail light gasket.
Old Oct 21, 2009 | 12:53 PM
SpEeDyX's Avatar
its more then likely the tail light gaskets, common prob on tegs, they like to leak
itsmedavid
Jul 18, 2007 04:32 AM
PatrickGSR94
Dec 2, 2004 09:50 AM
Ronin Integra8
May 25, 2003 08:38 AM
8alaRm
Jan 9, 2003 08:24 AM
vietboixstunnah
Sep 6, 2002 10:10 PM
