What's the deal with Fields and MAP check engine lights?
Old Aug 29, 2002 | 07:11 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default What's the deal with Fields and MAP check engine lights?
OK.
I have a fields VTEC controller. the thing works fine, except I get a code 3 MAP
CEL everytime I hit a bump.
I have swapped four MAP sensors.
made sure the wiring and connectios were OK
Checked for continuity from the MAP sensor to the Fields unit to the ECU.
I used a switch and bypassed the MAP signal, so the Fields doesn't mess with it.
I still use it at the track, but for daily driving I let the ECU have the MAP sensor to itself.
Am I the only one??
Old Aug 29, 2002 | 08:20 PM
ShiroX's Avatar
Default Re: What's the deal with Fields and MAP check engine lights? (Spaceballs the lunch box)
Dood i feel for you!!!
same **** happened to me
drove me F$)%$@@$@ nutZ!!
how much are you modifing your fuel curve ??
i think going past +-8 % ***** up the MAP
Old Aug 29, 2002 | 10:36 PM
chhuong's Avatar
Default Re: What's the deal with Fields and MAP check engine lights? (VTeC4TheChildren)
I had the same **** even with solid connections, but once I soldered the connections it fixed everything. So that's what i reccomend to you to do, but if you soldered everything allready then i don't know what to do!!
chasmataz
Honda S2000
Sep 9, 2009 09:53 PM
ek9 ferio
May 31, 2005 07:49 PM
dannydos
Dec 12, 2004 06:17 AM
