NSX caliper on ITR fitment question
Old Aug 29, 2002 | 06:46 PM
Dropspeed's Avatar
Default NSX caliper on ITR fitment question
Anyone running NSX calipers with rota slipstream in a 15"? Any fitment problems? What about stock ITR wheels? I have a chance to pick up a set for $200.
Mattj
[Modified by Dropspeed, 10:46 PM 8/29/2002]
Old Aug 29, 2002 | 07:30 PM
uNF$@#!'s Avatar
Default Re: NSX caliper on ITR fitment question (Dropspeed)
you will need to do some minor shaving to get them to fit.
Old Aug 29, 2002 | 08:33 PM
98itR484's Avatar
Default Re: NSX caliper on ITR fitment question (Soup ****)
talk to migs, he has the nsx calipers on stock ITR wheels
Old Aug 29, 2002 | 11:20 PM
migs's Avatar
Default Re: NSX caliper on ITR fitment question (98itR484)
Matt, the calipers should fit fine as long as they are 91-96 NSX. The later style NSX's had a different sized piston 97+, making wheel spacers mandatory.
1) It does not require any shaving to make them fit on your ITR knuckles.
2) If you use your stock ITR rotor (23mm), you will need about 5mm of shimming and you will ALSO need the NSX caliper bracket bolt. Runs about $4.xx from the dealership/piece.
3) If you use the Legend GS rotor (28mm), you will only need about 1-2mm shimming (one fat washer). You can also utilize your STOCK ITR caliper bracket mounting bolt.
4) They will tuck away under your ITR wheels just fine, I dont see why they wouldnt tuck away under Rotas.
Let these pictures explain the rest and let me know if you got any question.
ITR 23mm vs Legend GS 28mm
Arn, thanks for the AAA help, and we got that secret canyon run coming soon.
Old Aug 30, 2002 | 04:40 AM
ILUVTEC's Avatar
Default Re: NSX caliper on ITR fitment question (Migs)
And if you do not want to purchase those calipers, then let me know and I will buy them, thanks
Old Aug 30, 2002 | 04:59 AM
Willard's Avatar
Default Re: NSX caliper on ITR fitment question (ILUVTEC)
Old Aug 30, 2002 | 05:13 AM
Johnny Tran's Avatar
new record: 0-237 questions answered with a correct response..... great job!!!!
Old Aug 30, 2002 | 05:50 AM
Dave-ROR's Avatar
Default Re: NSX caliper on ITR fitment question (Johnny Tran)
hahahahhahahahahahhahahahahhaha x 3 million. good **** tran.
Old Aug 30, 2002 | 06:02 AM
Black R's Avatar
25 Year Member
.....weight?
.....shorter stopping distances?
.....and has anyone gone from these to sp00n and noticed even more of an improvement?
Old Aug 30, 2002 | 06:08 AM
migs's Avatar
Default Re: NSX caliper on ITR fitment question (Black R)
.....weight?
NSX calipers = 12lbs
Nothing by fact, its mostly be feel. IMO, I can stop a hell of alot better than before
4 piston vs 2 piston, Im sure
[Modified by Migs, 7:09 AM 8/30/2002]
Old Aug 30, 2002 | 06:09 AM
Anderson's Avatar
Old Aug 30, 2002 | 10:24 AM
Dropspeed's Avatar
Default Re: NSX caliper on ITR fitment question (Anderson)
Great, Thanks for all of the info, The calipers are currently on a 97ish prelude with 16" rotas. My friend is putting the car back to stock for sale. They come complete with every thing to make it fit and they have been powder coated a charcoal color. I can't pass up the deal.
Thanks again.
Mattj
CroSi
Suspension & Brakes
12
Aug 7, 2017 10:03 AM
dev203d
Suspension & Brakes
21
Dec 30, 2010 01:55 PM
Kamikaze_ITR
Sep 27, 2006 09:00 AM
SpoogenJay
Feb 23, 2005 06:37 PM
Money Hou$e
May 17, 2003 02:35 PM
