Suspension & Brakes Theory, alignment, spring rates....
**HELP!! did i get swindled?!**
Old Oct 20, 2009 | 03:53 PM
iheartjayDem's Avatar
Default **HELP!! did i get swindled?!**
i asked for brembo sport drilled rotors for an integra, aand they look nothing like the pictures on the internet. The boxes look like they were retaped, so it got me thinking. This is what i recieved, HELP!
Old Oct 22, 2009 | 11:01 AM
TunerN00b's Avatar
Default Re: **HELP!! did i get swindled?!**
So, you purchased rotors that were removed from the box, drilled full of holes, put back in the box, and the box taped shut and sent to you.
Isn't that what you intended to purchase?
Something to keep in mind about these purely cosmetic items(copy/paste from tirerack):
Originally Posted by tirerack.com
IMPORTANT REMINDER: Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed track use.
While grooved, drilled and slotted rotors offer an enhanced appearance and add some resistance to the boundary layer of gasses that can build up between the pad and rotor, they are not designed to withstand the extreme temperatures that are produced on the racetrack.
Old Oct 22, 2009 | 01:43 PM
Dang EG's Avatar
Also, you got the previous style rather then the new rotors brembo now has. The updated one come with check points where you know how much depth you have left on your rotors... OEM Brembo blanks would have done you just fine.
Just wanted to add that little info to it.
RedGSR
51
May 1, 2005 06:29 AM
lucasbkellner
Nov 13, 2004 08:33 PM
tunes12
Jun 12, 2003 03:38 AM
Floyd
Jul 8, 2002 08:59 AM
