Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission Leaking
Old Oct 20, 2009 | 03:36 PM
landon.alder's Avatar
Default Transmission Leaking
So my tranny has been leaking a little ever since I got this car. I don't know where it's leaking from and how to stop it. I really wanna fix it now that I put new fluid in it. Any help is much appreciated (sorry for the bad quality pics)
Old Oct 20, 2009 | 03:55 PM
Aquafina's Avatar
Default Re: Transmission Leaking
Trans isn't leaking. Leaks go down.
Old Oct 20, 2009 | 04:08 PM
do you have an idea what is?
Old Oct 20, 2009 | 04:27 PM
Evs-One's Avatar
Solbros Owns Me
If it's a non VTEC 95 Civic, could be the head gasket. Otherwise, could be the dist o ring, valve cover gasket, or the cam cap(removed and no sealant place back on before assembly).
Old Oct 21, 2009 | 03:55 PM
Thanks for the help. I'm gonna start a new thread with a bunch of new pics to make it easier to diagnose.
Old Oct 21, 2009 | 07:28 PM
night's Avatar
that is the dist oring and/or shaft seal. check the bottom of your dist cap. if it is wet you need a shaft seal.
also check your heater hose under it. it is probably about to pop.
jdmNit
Apr 1, 2010 08:47 PM
jeremypr
Aug 2, 2009 05:05 PM
Groove_D
Feb 26, 2006 06:15 PM
E36 Guy
Nov 8, 2003 09:55 PM
sivik2nr
Nov 26, 2002 12:30 PM
