accord won't start :( (no spark?)
Can you hear the fuel pump prime the system when you turn on the ign. switch to run, [not start]?
Have you checked to see if there is 12V+ at the injectors, [same wire color on all injectors] with the ign. key in run?
Have you checked to see if there is 12V+ at the distributor, [black/yellow]?
Pull a spark plug and see if you have spark. 94
octodigitus
Apr 24, 2017 06:55 AM
