Suspension & Brakes Theory, alignment, spring rates....
brake upgrades for an ls
Old Oct 20, 2009 | 12:40 PM
manthony14375's Avatar
Default brake upgrades for an ls
I need to know if I would be ok with just upgradeing my rotors and pads on my stock ls brakes . I do track the car but as of right now the car is only making 180 hp. Just needs some advice on what I should do about a brake set up .
Old Oct 20, 2009 | 06:22 PM
kommon_sense's Avatar
Default Re: brake upgrades for an ls
What problem are you trying to solve? What is wrong with your current setup?
Old Oct 22, 2009 | 10:27 AM
Well my current brakes are shot ..So I figure I would just upgrade my brakes with nicer rotors and pads. The current brakes are find for what I have for now but I plan on turbo the car this spring and I just want to make sure I have enough stopping power .
Old Oct 22, 2009 | 10:56 AM
TunerN00b's Avatar
Autozone Duralast rotors, good pads, fresh high temp rated brake fluid.
Hawk HP+ pads lasted me just fine on my GSR, running on the big track at Willow Springs on a 105* day. Integras have good brakes stock. Go for an even more aggressive pad if street duty isn't part of the equation.
No reason to use "nicer rotors". On a track car, rotors are a wear item. Run the cheapest ones you can, and replace them with the pads. You only need to consider "good" rotors when you try and run an enduro.
Old Oct 22, 2009 | 11:33 AM
Thanx for the input will do ....
elcid
Jul 25, 2008 11:04 AM
turnsignalandy
Nov 12, 2006 03:35 AM
blulude92
May 22, 2006 08:07 AM
EBPSI
Apr 4, 2002 09:12 AM
Petah
Aug 25, 2001 07:02 PM
