FS: Built GSR Head, Built GSR Block, S372r, T1, Fuel System and More !!!
looking to liquidate these parts -- pictures available upon request
Email -- James@IPGParts.com
Phone -- 407-324-4684
or PM
-- AIR Carbon B16/B18 Intake Manifold -- Set up for 8 Injectors -- includes the lower fuel rail as pictured, manifold flange is drilled for both the B16 and GSR Head Pattern -- Great intake manifold -- what you see is what you get -- $900
-- Function 7 Rear Lower Control Arms for 92-95 Civic, 94-01 Integra -- sold
-- Golden Eagle Scatter Shield for B Series -- sold
-- Skunk2 Composite Fuel Rail for B Series (includes fittings on the end as pictured) -- sold
-- AEM 30-1060 EMS -- $700
-- Complete Fuel System (includes fuel lines with fittings, weldon 2015 fuel pump, aeromotive fuel filters, etc), just add your fuel rail and injectors and you are ready to go -- $750
________________ can include a sumped gas tank for EG as well for an additional cost or will sell individual parts as requested
-- BW S372r Turbocharger -- T4 Flange, 1.10 A/R -- used on a race car so not much mileage at all on the turbo itself, makes great power and nicely priced -- freshly coated black turbine housing -- $1200
-- GSR Cylinder Head with Supertech Valve Springs, Retainers, Valves -- includes the Valve cover as pictured, vtec solenoid and intake manifold gasket -- $1100
-- OEM Integra Type R ( ITR ) Camshafts -- $300/pair
-- Window Net (needs to be recertified) -- $50
-- 5 Point Harness (needs to be recertified) -- $75
-- Autogage 5" Tachometer with Shift Light, black face, 10k rpm limit - $125
-- FJO Wideband -- complete with sensor, control box and gauge -- $300
-- Honda P28 ECU chipped for a DOHC Vtec Engine -- $140
-- Skunk2 Lowering Springs on OEM Shocks, completely assembled with top hats, etc, ready to bolt on -- fits 92-95 Civic, 94-01 Integra -- $225
or PM
or PM
or PM
check out our new all motor project car -- https://honda-tech.com/forums/all-motor-naturally-aspirated-44/ipg-all-motor-car-project-2667047/
check out our all motor car build -- https://honda-tech.com/forums/showthread.php?t=2667047
