shaking problem 95 eg.......
Old Oct 20, 2009 | 03:46 AM
sins's Avatar
Default shaking problem 95 eg.......
ok so yesterday evening my eg started shaking when im between 65 and 70mph so i had my tires balanced and still does the same thing...so today im changing the rear hub bearing cause its worn out and getting it aligned maybe thats what causing it to shake, but i idk it can be a number of things so lmk what you think honda-tech members thanks...
Old Oct 20, 2009 | 03:50 AM
civicgsr's Avatar
Default Re: shaking problem 95 eg.......
Could be a bad CV joint too. Sadly, there is a long list of possibilities.
You can always try rotating your tires to see if it happens at the exact same speeds.
This is a longer shot, how are your motor mounts? Are they really soggy?
Old Oct 20, 2009 | 07:20 AM
sins's Avatar
motor mounts are in good shape
Old Oct 20, 2009 | 07:56 AM
civicgsr's Avatar
Rotate the tires and see if you still have the same problem.
Old Oct 20, 2009 | 08:33 AM
Former User's Avatar
Return to the shop that balanced the wheels and have them do it again. The wheels are still out of balance.
Old Oct 20, 2009 | 12:06 PM
ReDJdMBuB's Avatar
i had the same problem but i had a bad wheel bearing in the front and my alignment was off. changed my bearing and got a alignment and problem went away
Old Oct 20, 2009 | 01:31 PM
sins's Avatar
thanks...they just finished changing my wheel bearing and alignment...ill see how it drives on my way home after work
Old Oct 20, 2009 | 01:47 PM
D Griff's Avatar
I had a similar problem; it was my cv joints...
Old Oct 20, 2009 | 05:05 PM
sins's Avatar
Tested the car out after having the hub bearing n aligment done n no luck it still shakes at 70mph
Old Oct 20, 2009 | 05:13 PM
Old Oct 20, 2009 | 05:20 PM
Cyberwaste's Avatar
tie rods!
Old Oct 21, 2009 | 03:36 AM
sins's Avatar
How do I check if the cv joints and tie rods are no good
Old Oct 21, 2009 | 04:29 AM
civicgsr's Avatar
I was thinking....CV joints usually only shake under load...unless they are in terrible shape or are bad rebuilds.
As for the tie rod ends, you can try to move the knuckle and see if there is any play in the tie rod end. It would almost have to be obvious for it to be a problem. Thing is, you'd have really bad tire wear on the inside edge if the tie rod(s) were bad.
Old Oct 21, 2009 | 08:53 AM
sins's Avatar
Default IRe: shaking problem 95 eg.......
Have a donor car at home ill swap the cv joints from that one to my car
Old Oct 22, 2009 | 04:06 PM
sins's Avatar
Also forgot to add that when I hit small bumps on the highway it also shakes n wants to pull to the right
Old Oct 22, 2009 | 05:22 PM
j0keefe21's Avatar
the shaking at highway speeds sounds like a dynamic tire imbalance to me. the the pulling to the right when you hit a bump has to be worn suspension. jack your front end up and move your tire around and see if anything is lose.
Old Oct 22, 2009 | 07:37 PM
shogee's Avatar
sounds like a bent tierod or something bent in your steering and suspension a bent tierod usually show up when hittin bumps. honestly if your front end is loose they shouln't even align the car. its gonna just throw off your alignment because you cant align something that flops around. did they recommend for you replace anything at that shop. can you list
Old Oct 23, 2009 | 03:40 AM
sins's Avatar
Ill be taking back to the place where they did my hub bearing n see what they tell me
Old Oct 23, 2009 | 06:06 AM
sins's Avatar
took the car back to mechanic he told me i need to change the rack n pinion and also the front sruts......so my question is since i have a ex 2 door donor car at home would the rack n pinion from that fit my 2 door dx
Mk_avsegb18
Aug 28, 2016 11:12 AM
mxracer420
Oct 5, 2009 08:31 PM
buzlink
Jul 23, 2008 05:26 PM
after nine30
Jun 15, 2007 03:18 PM
.Grimace
Sep 7, 2005 10:26 PM
