Engine clacking on start up (cold weather)
I was driving my car without any oil (dip stick was dry when i checked) for about 3 weeks and now there is alot of clacking (sounds like valve clap) on start up until the engine gets warm. Its really loud now even after i filled the oil back up. I know it wasn't smart (its my beater) but i want to know if I can fix it or if I should swap in another D
What is the cause of this?
Expensive to fix?
This is all on a d16y7 with approximately 200 000kms on it.
Expensive to fix?
Man $5 worth of oil and 2 mins of your time would ahve saved you all this mess.....I dont know why you didnt fill it up when you knew the dipstick was reading dry. That's like knowing your going to sh*t your pants if you fart but you let a ripper go anyways...
I agree with CivicGSR though, you have no idea what kind of damage has been done to the block
no need for "you should have" lectures more like some answers to my questions
your internal probbly fried but you wont know till you open it. the oil stays on the bottom when its not on. when you start the car, about 30secs. oil start moving up thats why you dont hear that crakling sounds. if you dont have the money right now it, run it with 10w30 to protect those piston rings etc. but get it fix asap before it gets worst. are you west, mid or east of canada.
lucas maybe? i know people that like it. i dont use it.
just keep the oil changed every 3k or under. DO NOT drive it hard if you want it to last at all..
But i do agree with the others about finding a new motor. they are a dime a dozen.
good luck
good luck
thanks everyone... im in quebec so the winters get pretty cold here.
Im gonna try to adjust the valves first to see if that will make a difference. This time of year its hard to find a d in good condition so im gonna wait to see what the results give with a valve adjustment
A spun bearing will make a knocking sound. You should use a heavier weight oil. 20W-50 or straight 30W to see if it quiet down some of the noise.
but a heavier oil can help. 15w-40 would work as well. straight 30w
would probably be the best though
ferio252
Dec 15, 2010 12:29 PM
Sinner
Jun 16, 2003 10:09 PM
