Speed Sensor
Hey does anybody have a write up or a diagram on the speed sensor? I've tried to search for it but haven't found how to put it in. Also what do you guys think about buying an ebay sensor?
http://cgi.ebay.com/ebaymotors/1995-...#ht_8260wt_714
Write up or diagram in regards to what? Replacing it?
It's on top of the transmission held in by 2 bolts if I recall and is below the TB/Dizzy area remove the intake arm to access it
yeah in regards to replacing it. I'm not use to honda's at all so i'm totally new when it comes to them. And it's a 95 v6. So it's probably not quiet the same as you were explaining it.
You need to list details like that in your first post - you'll probably want to verify the 4cyl and 6cyl use the same VSS before buying it. That eBay auction does not seem to specify.
Player77--I would love to help you out, but the first step is learning proper english. I can't put in any input if i can't even understand what the hell your asking....
"when working when no working"
Have you read the thread?
If you have:
- no cruise
- a CEL
- the speedometer/odometer aren't working
Then it's most likely the VSS.
If you have:
- cruise
- no CEL
- speedometer/odometer aren't working
Then it's most likely the cluster itself.
I don't think it can be made any clearer than that.
This makes no sense.
If you have:
- no cruise
- a CEL
If you have:
- cruise
- no CEL
If you have:
- no cruise
- a CEL
If you have:
- cruise
- no CEL
I'm pretty sure muffin man is a full time mechanic. Don't diss on what you don't know
Your CEL may have a bulb burnt out, or you may have an intermittent VSS.
I've seen before where a user bought a car where the seller REMOVED the bulb for the CEL to mask the problem.
As to my life I:
- full time student (15 credit hours)
- work 20+ hours a week
- work on both my S2000 and Accord
- had a H22A swapped Accord with pretty much every mod available save for building the motor
I know what I'm talking about, that post was in response to player77, not yours.
I was one of the guys that figured out the fix for a faulty cluster. After spending like $200 for a new OEM VSS and cluster parts
