Honda Engine Rebuild Partout New
I have one of each items listed below (B) = B-SERIES will not ship pick up only ANY QUESTIONS CALL OR TEXT (909)935-9060 John
TOP LINE ITR OIL PUMPS $90
OEM TIMING BELTS (B) $70
OEM REPLACEMENT TIMING BELTS (B) $40
OEM REPLACEMENT HEAD GASKET SET(B)(HEAD GASKET,VALVE COVER GASKET,GROMMETS, VALVE SEALS,INTAKE AND EXHAUST MANIFOLD GASKET) (B) $100
BOTTOM END GASKET SET (B) (OIL PAN, MAIN SEAL, REAR MAIN SEAL) $40
NIPPON RACING PISTONS AND RINGS STD, .25, .50, .75 OVER. $150 A SET
B16, LS, GSR, ITR, CTR, B20
ACL ROD BEARINGS $30
ACL MAIN BEARINGS $30
THRUST WASHERS $12
ACL RACE BEARINGS SET (ROD,MAIN,THRUST) $125
ARP LS/B20 ROD BOLTS $45
ARP B16/GSR ROD BOLTS $80
ARP HEAD STUDS (B) $140
GOLDEN EAGLE HEAD STUDS (B) $120
HIGH END TRI-Y B SERIES HEADERS $350
BDL BLOCK GUARDS/SAVER $70
Billet Aluminum ONE BELT LIGHT WEIGHT B-SERIES PULLEY. BALANCED TO 10,000 RPM'S. LIGHTER THEN CTR, AND CAN USE STOCK BELT. $100
BLOX B-SERIES DUAL VALVE SPRINGS $130
RETAINERS B-SERIES $120
THRUST WASHERS $12
GOOD prices for some REbuild parts...
BAck to the top for you and i still have your PISTON,I'll be in your area soon...
bambam
2157
Mar 23, 2025 09:34 PM
kaminsknator
Engine Machining & Assembly
Oct 28, 2017 02:01 PM
STHPERFORMANCE
Nov 1, 2002 08:13 AM
