Valve adjustments
I’m reading up on the service manual and I see the specs calls for
Intake: 0.08 – 0.12 mm
Exhaust: 0.16 – 0.20 mm
What are the differences if I were to adjust my intake to .12 mm as opposed to .08 mm or vice versa? Same question goes for the exhaust valves? Will running tighter clearances give me less power? I have a stock B18B in my DD and I noticed its kinda loud. Any preference?
I usually do my adjustments on the tighter side of specs...
Thats my personal preference. You will not see significant power being gained from an adjustment, so just make sure you are within spec and you will be ok.
