Rough idle and sluggish aceleration
Old Oct 19, 2009 | 11:21 AM
preludequestion's Avatar
Default Rough idle and sluggish aceleration
Hello,
I recently purchased a 2000 Honda Civic SiR and I am now having issues with a really rough idle and sluggish acceleration. It will idle smoothly at 1000 rpm or so, but then like every 10-15 seconds it goes down to 400 rpm, almost ready to stall and then it goes back up. Not sure whta might be causing this issue. I have recently changed the air filter.
Now i know that my car did not have the PCV hose, so I put that on. Ever since then, as far as I can tell, I have been having this issue. I think that my PCV valve might be dirty, or broken? Could it be the sparkplugs, even though the car starts just fine? The car seems to be slow at accelerating and then all of a sudden at 3500 or so, it seems to breathe more air and takes off. Like normal.
PCV hose/valve, spark plugs, Fuel injectors maybe? Could it be the Fuel filter? It just seems odd that it is now happening since I put on the PCV hose. Possibly it was removed because PCV valve is damaged or unusable. I will try shaking the valve.. to hear for the rattle..
Anyone else have these same issues?? It ran beautifully before this Thanks!
Old Oct 19, 2009 | 11:28 AM
Former User's Avatar
Default Re: Rough idle and sluggish aceleration
Start by replacing the plugs, wires, cap, and rotor and checking the ignition timing. Then clean the IACV on the throttle body.
Any CEL codes?
Old Oct 19, 2009 | 11:36 AM
I have not had a chance to look at CEL codes, sorry. I will check the plugs, wires and cap. Sorry but what do you mean by rotor? I am not really mechanically inclined, the rotors that I know about are the ones for your brakes. Thanks though information. I have a feeling something clogging up.
Old Oct 19, 2009 | 11:39 AM
The rotor is inside the distributor:
Old Oct 19, 2009 | 11:41 AM
-__-'s Avatar
the rotor he is talking about is found underneath the distributor cap.
replace all that stuff and your PCV valve (they are cheap) and then re-do your timing
Hooked911
Mar 26, 2013 01:14 PM
jojogalan
18
Jul 14, 2007 11:51 PM
k20rex
Jul 21, 2006 02:19 AM
JDM_SOHC
May 3, 2005 04:40 AM
caliquick_teg
Jan 23, 2003 05:34 AM
