Ek H22 wiring
Old Oct 19, 2009 | 08:45 AM
hammergunner's Avatar
Default Ek H22 wiring
got everything done, motors in clean, everything is bolted in and hooked up, now comes the wiring
i've done mostly everything already with the wiring, wiring up the newer plugs for the older motor.
and i have everything done but the dual butter files, which i will run to the obd1 h22 ecu via the jumper.
and the purge solenoid, which i dont have a clue where its at on the EK harness
so i might wire that to the jumper aswell.
so speaking, has anyone does this wiring conversion before and if so, do you have any helpful hints
and i've been looking at ecu pinouts for the p13 ecu, and i was wondering i just have a normal obd2a to obd1 jumper, will it still work with the ecu?
and since im using the obd1 p13 ecu will i have to do the OBD2a CKF mod?
and for F*@K SAKE please don't ask other questions that are not on topic.
OutlawCL
Mar 14, 2005 03:37 AM
st0nedstoopid
Jun 24, 2003 10:55 PM
