Suspension & Brakes Theory, alignment, spring rates....
Will rear ITR LCA'S fit EK/EJ8 ??
Old Oct 18, 2009 | 08:52 PM
Dasanib20T's Avatar
Default Will rear ITR LCA'S fit EK/EJ8 ??
I have a set of Tokico Blue Struts / Neuspeed Springs from my ITR. So I am wondering if I can buy ITR rear lower control arms and everything will bolt up ??
Old Oct 18, 2009 | 09:17 PM
JDM_EK_wanabe's Avatar
Default Re: Will rear ITR LCA'S fit EK/EJ8 ??
nope, the ITR LCAs dont fit the EKs, you must use EK LCAs as they are longer than EG/DC, but your shocks will fit perfectly fine with the exception of your rear shocks having a little gap between the shock and LCA bushing, but that can be fixed with a couple washers
Old Oct 18, 2009 | 11:45 PM
ramen's Avatar
Nope ITR LCAs won't fit because the Ek ones are longer then the ITR ones.
Old Oct 19, 2009 | 05:20 AM
phunhaus's Avatar
In order to use ITR eyelet shocks on an EK you need the Function 7 ITR-spec EK arms.
cnydc2
Feb 26, 2008 07:59 PM
hanson said
12
Nov 29, 2004 07:58 PM
lDanny
13
Jun 10, 2004 02:00 PM
SoCaLNaTIvE
Feb 18, 2004 07:40 AM
Wazup
Feb 14, 2003 07:15 AM
