i need this gasket
Old Oct 18, 2009 | 08:12 PM
Cyberwaste's Avatar
Default i need this gasket
ok so i have an ebay header on my car
its a 4-2-1 and the middle gasket is shot like they all do
is there a place where i can get this gasket???
and i have heard that you can use bronze????
any ideas or info would be nice
thanks
Old Oct 18, 2009 | 08:14 PM
ej8ster96's Avatar
Default Re: i need this gasket
would like to know the same thing!!
Old Oct 18, 2009 | 08:15 PM
Cyberwaste's Avatar
lol
bump x2
Old Oct 18, 2009 | 08:18 PM
R666_EK's Avatar
Which middle gasket?
The one between the upper and lower parts of the manifold? Or between the collector and cat?
You will probably need to order one. Stock manifolds use O-Rings which are completely different than a lot of aftermarket ones.
You could also make one, if you get some gasket material.
Old Oct 18, 2009 | 08:21 PM
R666_EK's Avatar
Is this what you are talking about?
Cyberwaste's Avatar
where the header its self is bolted together
not the o ring and not the gasket that is on the head
sorry i didnt make this clear before
Cyberwaste's Avatar
yes!
Old Oct 18, 2009 | 08:22 PM
ej8ster96's Avatar
yes thats the gasket, atleast the one i need
Old Oct 18, 2009 | 08:24 PM
st0xafella's Avatar
HAPPENED TO ME ONCE...SUMMITRACING.COM SHOULD HAVE THEM..IF NOT AUTOZONE SALES SOME SIMILAR BUY THERE A LIL BIGGER I JUST MADE IT WORK..
R666_EK's Avatar
Ebay has a lot of em.
You can get it for around $15
Old Oct 18, 2009 | 08:25 PM
jayWknight's Avatar
If not, you can use copper ultra gasket maker.
Old Oct 18, 2009 | 08:27 PM
ej8ster96's Avatar
i used this on my old header, worked really well, just looks sloppy
uberEFtuner
Apr 24, 2019 08:38 AM
SuciaEk420
Jan 1, 2012 03:29 PM
jonnybadboi9
May 8, 2008 06:16 PM
ImportsCRX
Feb 28, 2004 10:48 PM
