HELP with suspension please?
Old Oct 18, 2009 | 06:58 PM
rhdjeezy's Avatar
Default HELP with suspension please?
Hi.
I have a real JDM 93 Honda Civic Eg6 my current suspension setup is:
00 itr 32mm 5 lug
Silkroad Section rma8 coilovers
Skunk2 pro series Front & Rear camber kit
Polished asr sub brace
Function7 itr lca's with spherical bearings
My question is, I want to get the Tein Flex coilovers, but the dude I'm trying 2 buy them from has the jdm itr 5 lug 36mm conversion. Will they fit OK, NO PROBLEMS?
Yes I know this could be a dumb question, but I'm not about to spend $750 on something I'm not sure of, Can anyone help me?
Old Oct 18, 2009 | 07:21 PM
Mfoehrkolb's Avatar
Default Re: HELP with suspension please?
Responding from your PM.
I don't see any logical reason that the 32mm and 36mm set up's wouldn't allow to run the same suspension... The only difference between the 2 would be the size of axle which has no correlation to the coilover itself.
In actualitie the axles themselves are pretty similar minus the fact of the mm difference...
I don't know 100% but i quite the knowledgeable one, and i would trust my info unless anyone else can offer REASONABLE LOGIC of why i wouldn't be correct...
Old Oct 18, 2009 | 08:05 PM
Rok_Stok's Avatar
I'm 99.9% sure they'll fit your car. One good way to find out is to shop around for coilovers and see if the part numbers are different for JDM and USDM Type-Rs, but there probably isn't any USDM or JDM designation on them.
Old Oct 18, 2009 | 08:53 PM
civic_r87111's Avatar
I have swapped USDM Type R shocks and springs with USDM GSR's and LS's so I'm 99.9% sure as well.
treeafodo
Nov 19, 2013 03:22 AM
Rikz
Aug 6, 2008 09:33 AM
MurdersV8s
Sep 18, 2006 03:54 PM
maxboost_50psi
Jul 3, 2005 02:08 PM
92TypeR
May 15, 2002 12:35 AM
