How to adjust the window in the door?
Old Aug 29, 2002 | 04:12 PM
TimsTeg's Avatar
Default How to adjust the window in the door?
My car got broken into and the window doesn't quite roll up right. It sags in the front so it misses the track on the rear side of the door. Anybody know how to adjust it?
Old Aug 30, 2002 | 09:08 AM
TimsTeg's Avatar
Default Re: How to adjust the window in the door? (Accord092)
anybody?
Old Aug 30, 2002 | 11:55 AM
civbeater90's Avatar
basically there is a front track that your window slides down on.you will notice a seies of bolts once ytou remove your doorpanel.if i remeber correctly when i did mine.the 2 modt forward ones,are the adjusters for the window.make very minmal adjustments or else you 'll be there all day.hopefully one of the bolts came loose.you might be able to notice where it was once positioned.good luck.and having someone help is good too.
hondaslave1342
Feb 6, 2019 04:07 PM
RchCrr
Jun 25, 2012 07:38 AM
crxaddikt
14
Jun 21, 2011 11:32 AM
inaety
Jun 7, 2010 11:53 PM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
