pushing coolant under boost!!!!
ok so i oringed the head with a copper gasket...... i was told it was a head gastket problem. we put it back together and the same thing.... only under boost. i was told to retighten the studs because the head was lifting. i was also told to check the thermostat and the radiator cap...... any suggestions? before i put this new head gasket on you could smell the exhaust in the overflow. now you cant!!!!! im lost. please help
you have air coming into the system somewhere. since you've changed the headgasket go ahead and try the radiator cap. why aren't you using a OE headgasket?
We were using honda gaskets and it blew under high boost..... so that's when I took off the head and had it oringed....... radiator cap is my last choice..... anymore ideas??????
Lei Siew Long
May 30, 2002 03:32 PM
