Idle/start issues hunting rpm
Old Oct 18, 2009 | 03:09 PM
canadianr's Avatar
New User
Default Idle/start issues hunting rpm
Hi,
I am working on a 4th generation prelude with the h22 engine in it.
The symptoms that the car is showing are that the idle is going up and down between 1k and 2k rpm, upon initial cold start up. What can cause this? Is there a switch or valve that is malfunctioning? A fast idle control solenoid perhaps? when the car is warm, the idle is steady.
I come from a nissan background, if it counts for anything.
Old Oct 18, 2009 | 05:06 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Idle/start issues hunting rpm
There is a fast idle valve that is a common culprit to this problem, search the archives....
Old Oct 18, 2009 | 06:09 PM
canadianr's Avatar
New User
thanks for the reply.
I will have a look through the archives to see. Thanks for the info!
Old Oct 18, 2009 | 06:13 PM
THC07's Avatar
that brass looking cap on the back of the FITV. (under TB)
Open cap, tighten white cap all the way down. put brass cap back on, problem solved.
Old Oct 18, 2009 | 09:33 PM
JDMP-BB2's Avatar
New User
Look for the idler control valve
Old Oct 19, 2009 | 09:10 AM
THC07's Avatar
umm, No. fix your FITV before you chage your idle via ICV.
He said its hunting when its COLD
TearSDMF89dx
Jan 3, 2012 04:31 AM
turbodailydan
Engine Management and Tuning
Feb 27, 2010 01:07 PM
turbodailydan
Feb 24, 2010 08:59 AM
PorscheGT2
Feb 8, 2002 03:36 AM
