srp 9.1 comp ls pistons in B16????
Old Oct 18, 2009 | 02:38 PM
Civic89stdB16's Avatar
Default srp 9.1 comp ls pistons in B16????
hey I have a set of srp 9.1 to 1 comp pistons that are 81.5mm and are for a b18a/b and my question is can I use these in My b16 without any valve clearance issues. Or will I have to grind out the valve reliefs for the vtec valves and it will have blox type b cams. Please someone help me out. I also do not know the part # because its not on the bottom of the pistons. thanks
Old Oct 18, 2009 | 07:13 PM
blinx9900's Avatar
Default Re: srp 9.1 comp ls pistons in B16????
post pics please, most forged pistons have huge valve reliefs regardless if there for vtec or ls motors.
Old Oct 19, 2009 | 12:43 AM
gotboosthatch's Avatar
then they are not srp.. all srp's have the p/n on the bottom right under where the wrist pin goes
Old Oct 19, 2009 | 07:28 AM
b20beast83's Avatar
afaik, they are not a pt# but a casting #
Old Oct 19, 2009 | 12:12 PM
there r some pics. thanks
Old Oct 19, 2009 | 12:21 PM
blaze the chemi's Avatar
Install one and clay it. Yum....deep dish.
Old Oct 19, 2009 | 07:14 PM
I should have .022 inches piston to deck clearance according to the zeal compression calculator. I just want to be sure but in not trying to put it together and clay it to find out I just have to take it apart and get other pistons. thanks
Old Oct 21, 2009 | 04:47 AM
b20beast83's Avatar
those look lower than 9:1
Old Oct 21, 2009 | 05:27 AM
civicjunkie17's Avatar
yeah they do. they seem like 8:1. did you even bore your block?
Old Oct 21, 2009 | 07:26 AM
why
Old Oct 21, 2009 | 07:27 AM
these in my b16 should be around 8.2 to 1 comp.
haas480
Jul 27, 2009 10:15 AM
Civic89stdB16
Dec 17, 2008 03:26 PM
turbohf
Jan 29, 2003 07:41 PM
yellowcivic
Mar 15, 2002 10:57 AM
