advice on removing a/c + c/c on sohc turbo
Old Oct 18, 2009 | 02:49 AM
sDc5's Avatar
Post advice on removing a/c + c/c on sohc turbo
hey fellow h-techers
i am currently living in san diego, where conditions is pretty much sun every day, and i drive a 93 ej1 sohc vtec d15b with t3t4 setup pretty much close to stock except few upgrade on fuel setup, i am thinking of removing the a/c and c/c mostly because its not running and i plan to keep the car so dont care too much bout sellers appeal even thought the car is 16 years living.
i'm pretty set on removing just need some guidance on the way i should handle it
Old Oct 18, 2009 | 03:10 AM
NFrank89's Avatar
Default Re: advice on removing a/c + c/c on sohc turbo
if neither are running then go for it, the only thing i have to say is make sure you look into how to get rid of the refrigerant because i think it really messes up the atmosphere or something.
as for the CC, did you check the fuse? lol
Old Oct 18, 2009 | 05:49 AM
R666_EK's Avatar
Just pull it out. I don't know what you are asking for.
If its part of the A/C, Remove it. Part of the Cruise, Remove it.
If you really wanted to be thorough on the A/C removal you can also pull the dash and remove the evaporator. But its not really necessary.
Old Oct 18, 2009 | 07:12 PM
sDc5's Avatar
yea the problem is i cant find a step by step on doing it myself, yes its a shame but i'm askin for detailed writeups if possible
Old Oct 18, 2009 | 07:34 PM
landon.alder's Avatar
I'm interested in how to remove mine too, and I haven't found a good writeup. Here in washington I barely ever need it
CALM_AS_A_BOMB
64
Mar 13, 2006 06:35 AM
jdmcivic1999
Jan 31, 2005 06:34 AM
TurBoXBirD16
Jan 20, 2003 04:02 AM
StinkyTofu
Apr 19, 2002 07:18 PM
HiFi Civic
Sep 27, 2001 04:56 PM
