block swap question
Old Oct 17, 2009 | 01:31 PM
BubbleSnail's Avatar
Default block swap question
I have a 92 civic hatch, stock obd1 motor. Can I swap an obd0 block straight over, using my stock ecu and wiring harness? Or are there things that need to be done to make it compatible with an obd1 head?
Old Oct 17, 2009 | 01:39 PM
ek-g6's Avatar
Default Re: block swap question
It would be just about everything compatible, just use your obd-1 stuff. i.e. intake manifold and sensors, injectors, ecu, and thermostat housing, etc...
Old Oct 17, 2009 | 02:01 PM
R666_EK's Avatar
No. The block itself has nothing to do with OBD.
Everything OBD1 is on the head. As long as you use the old one you are good to go.
Old Oct 17, 2009 | 03:43 PM
Thats what I thought, just wanted to make sure.
Thanks
spooncivic1
Jul 27, 2006 04:57 PM
pearl
Feb 28, 2006 11:11 AM
