Suspension & Brakes Theory, alignment, spring rates....
NEED SOME OPINIONS! 92 4 door suspension/steering issues!
Old Oct 17, 2009 | 10:27 AM
vgalione's Avatar
Icon2 NEED SOME OPINIONS! 92 4 door suspension/steering issues!
Ok, Im going to explain my problems the best I can so I can get some opinions.
PROBLEMS: When I am at a dead stop and go to turn the wheel left there is a loud pop coming from the drivers side in the front. And while driving at pretty much any speed when I hit bumps the car jolts and almost feels like its pulling really hard to the right, almost like Im going to loose control.
WHAT I HAVE DONE: I have a 1992 4 door civ. Its manual of course. The car is suppose to have power steering, but its been plugged for a few years now. I have recently put in nice new buddy club upper control arms in, new ball joints on passenger side and new upper ball joint on drivers side, passenger is bad i know, i had the tie rod replaced on the passenger side, the drivers side has a rip in the boot, the axles are fine, wheel bearings are fine, i put a rear sway bar in (aftermarket), and to match I put a front sway bar. I know that the ball joing and tie rod on drivers side are a problem, but I have a feeling its something bigger than that. So if someone can give me some opinions on what they think I'd greatly appreciate it. My feeling is that the rack is going, I am replacing everything by next weekend (balljoint, tie rod, control arm bushings, im swapping a b18 in, and changing the rack of course) I just don't want to me missing something in case, although Im pretty sure that should cover it all. I have to drive the car all week, so Im wondering if maybe theres a quick fix so I don't kill myself driving it before next weekend.
btw i am using my boyfriends name to ask this, so don't mind if my terminology is off a bit, if you need better explaining I can try. Thanks!
Old Oct 17, 2009 | 12:26 PM
Tyson's Avatar
Default Re: NEED SOME OPINIONS! 92 4 door suspension/steering issues!
theres probably no quick fix to this.
fix what you know is a problem first.
check the installation of those upper control arms, aftermarket stuff isnt quality so i wouldnt rule out them just being in bad shape already.
and you need to get an alignment probably.
Old Oct 17, 2009 | 05:30 PM
vgalione's Avatar
yep, i actually decided not to wait and pulled it in the garage about 5 hours ago, swappin all the front suspension and motor, but def gonna get an alignment monday!
Old Oct 17, 2009 | 05:55 PM
Tyson's Avatar
you can check the condition of you steering rack by shaking the rack itself as it sticks out under the boot. if the boot is torn (and for a long time), the rack is already gonna be toast for sure.
Tegraracer90
Dec 12, 2014 06:40 AM
wheelerboy12
Jun 15, 2013 12:58 PM
tag0617
Aug 23, 2010 10:33 AM
crxaddikt
14
Sep 9, 2005 01:19 PM
