H22 Bearing Help!!
Old Oct 17, 2009 | 09:19 AM
Team H2B's Avatar
Icon2 H22 Bearing Help!!
i have a h22a1 that recenlt spun a rod..sent i to the shop got it fixed..shop used cheap bearings and 1 spun again..i took out the bearings and the crank is still good. so heres were it gets confusing for me..the bearings i took out say ".5" and where from king bearings..they said the crank was shaved down 20k..soo i bought green oem bearings..2 small..i bought black..to small, but less play then the standard green ones..so now the only color left is blue..but before i waste any more money i would like to know if they will fit, or should i go with acl? but then i cant find anywhere that sells acl to match the size i need..any help is appriciated..thanks
Old Oct 17, 2009 | 09:23 AM
street_ride14's Avatar
Default Re: H22 Bearing Help!!
How are you measuring if your bearings are sized correctly ? .. You can plastigage. Or are you measuring amount of play ?
Old Oct 17, 2009 | 10:36 AM
Team H2B's Avatar
they wer already measured, i need a bearing 20k over sized says the shop.. im guessing its blue cus its the last color i didnt try lol
Old Oct 17, 2009 | 11:55 AM
Team H2B's Avatar
bumpp!
Old Oct 17, 2009 | 12:19 PM
Team H2B's Avatar
bumpp!
Old Oct 17, 2009 | 06:05 PM
Don't guess, you have all the numbers in front of you. Grab a Helms manual and look up the specs that Honda says you should use in relation to your current crankshaft sizing.
Old Oct 17, 2009 | 08:48 PM
cr8ter's Avatar
do not buy any oem bearings....your connecting rod was regrounded so any oem will not fit because they are meant for stock size cranks it will be a waste of money...u need to get .020'' oversize aftermarket bearings
Old Oct 18, 2009 | 06:52 AM
Team H2B's Avatar
ok thanks, but 1 question, the bearings that im took out that worked after the regrounding said ".5" does that have anything to do with anything?
Old Oct 18, 2009 | 07:43 AM
riceburner700's Avatar
i would find another h22 crank that hasn't been ground down and switch back to OEM honda bearings. right now you have to run an oversized bearing
Old Oct 18, 2009 | 08:38 AM
92civic_hatch's Avatar
i agree with him ^. itd be a pain in the *** to run one oversized bearing, and thats what you would have to do, unless you got your other three rods machined as well. plastigauge would be very easy to use with a crank and rod out of the block, i would use it if you do plan on going with the rod and crank you already have. you could be sure of the correct bearing size to use.
Old Oct 18, 2009 | 09:49 AM
Team H2B's Avatar
all the bearings are the ssame all over sized, i guess my question now is where can i find acl oversized bearings?
Old Oct 18, 2009 | 12:25 PM
cr8ter's Avatar
im guessing the .5'' is the oversize but it don't make sense since u say it was regrounded .020'' oversize....u can get them on ebay....i agree with riceburner....honda cranks go through a special hardening process and once that layer is broken either by scratching or in your case regrounding they are junk and u will prolly gonna have problems with this again...honda cranks and cams are not too good after it has been regrounded
racereaper7
Jul 10, 2014 03:57 PM
uboostivtec
Jul 6, 2013 01:57 PM
hovic
Apr 1, 2012 10:45 AM
Peter Brady onlyonweekndz
Nov 2, 2007 09:05 AM
D.Dappa
Jul 16, 2007 01:57 PM
