Wont turn over...........
So I relocated my battery to the back of my ef. Now when I try to start I'm just get an extremely fast clicking sound. Could it be a ground issue or something ells I am not thinking of. Car started fine before the relocation and I rechecked my wiring severl times.
MM&Y of car???
How long is batt. cable?
Where is the cable that runs from the batt., [batt. pos.(+)] to front of car connected?
What gauge is that cable?
What kind of fuse/breaker are you using?
What gauge is the batt. ground?
How long is the batt. ground and where and how is it connected? 94
MM&Y of car???
What gage is the batt. ground?
There could be soo many things wrong... answer these questions for us please. especially where the grounds connected and what gauge cables you are using. Make sure all connections are tight, on starter and battery.
When I relocated the battery in my ef to the back I was able to still start my b18 with the same old battery I had to crank the single cam... You could have a low battery charge though. Check it quick with a multimeter..
SpecialRequest
15
Jan 2, 2018 09:05 AM
