Resistor box on stock motor?
I am swapping an ek tomorrow and the motor that was in it before had 1000cc injectors with a resistor box. I was wondering if i could leave the resistor box in and be fine with stock injectors on a stock ls? Thanks
the resistor box is used with low impendance injectors. in other words, if you checked them on an ohmmeter, they should read 2.5-3.5 ohms of resistamce i believe. high impedance injectors will show a reading of 12.-12.5 or so and they do not require a resistor box. im almost certain all honda obd1 injectors are low impedance.
I'm not sure how you have your box wired in. Here is a wire diagram I made a few months back for wiring up high & low impedance injectors.
Hope this helps.
Cheers
Hope this helps.
Cheers
ej1serge
Mar 14, 2012 11:33 PM
