2000 LX Misses after adding gas
Old Oct 16, 2009 | 05:45 PM
billy barker's Avatar
Default 2000 LX Misses after adding gas
Here's an interesting one for your consideration. My 2000 Civic LX (d16y7- non-vtec) misses very badly after I put in gas. I have to gun the engine carefully for a short time to make sure it wont stall out. It finally runs smoothly until the next fill up. There is vacuum when I remove the gas cap.
This all started out very inconsistently about 1 year ago, but it does it virtually every time I fill up now.This car did have the dreaded DTC p1457 error and I replaced the EVAP Bypass Solenoid Valve (located by the gas tank) with P/N 17012-S01-A002 per Honda's service bulletin 03-001. The error is back and I have the above stalling issue. Any ideas, anyone? Thanks in advance for the help!
Old Oct 16, 2009 | 05:53 PM
ferio252's Avatar
Default Re: 2000 LX Misses after adding gas
Bump for someone to help this guy out.
Wow. I have to say, your grammer is excellent! What a breath of fresh air to read your problem when you state it the way you did
Old Oct 19, 2009 | 02:13 PM
ferio252's Avatar
Bump
Old Oct 20, 2009 | 05:05 PM
BUMP, PLEASE!
Old Oct 20, 2009 | 05:17 PM
SergEK's Avatar
I had a similar issue but on my 99 it was the ignition unit -- Honda changed it out -- it would be at a stop light and then just die....if I didnt give it gas it would just die out. Apparently something in the key/ignition was messed up on a number of units and they didnt a TSB for it.
The only time after that I encountered the issue was on my EG -- IACV went bad -- friend helped me put a new (used) one in. No stalling.
Good luck
Old Oct 23, 2009 | 07:11 AM
Thanks for the reply.
xpistachiox
Aug 6, 2013 11:32 AM
Brewbot87
May 6, 2013 07:15 PM
4prosales
Dec 4, 2011 12:35 PM
kingrukus
Jun 20, 2010 05:53 PM
khan1977
May 27, 2008 08:44 AM
