car idles funny
The idle on my Y8 is really quite rough. It dips between 600-750 all the time, and when I take it out of gear it drops to like 250, then slowly climbs back off, shaking and making weird vibrations. It runs perfectly smooth when I accelarate, it's just when it sits and when I take it out of gear and coast. Once when it was idling at around 450 it kicked up to 750 and smoothed out. What could be causing this? I think my cam/crank alignment may be off, is there anything else I can check as well?
[Modified by 89_Y_49, 10:52 PM 8/29/2002]
Thanks for the help Tortex... Also, when I drove it home from work at like 1:00am it was running pretty well - the idle didn't dip, though it was still a teensy bit rough. It was great compared to earlier in the day. I fiddled with the cam gear and it didn't help, same with timing, but I'll check my vacuum lines and idle adjustment screw as well. I think I may do a valve adjustment too.
How do you check the evac and coolant temperature sensors, and why would the CTS affect the idle?
downest
May 23, 2006 10:05 PM
notsojdmeg
Dec 2, 2005 11:26 AM
