Top to bottom rebuild results in a troubling noise...
Old Oct 16, 2009 | 02:52 PM
FinalFlash's Avatar
New User
Icon3 Top to bottom rebuild results in a troubling noise...
Just finished a bottom to top rebuild (minus rotating assembly) on a stock 92 H23. We now have an odd rattling noise coming from the distributor that resonates accross the entire motor. Idle is a little jumpy but strong. At operating temp, the car idles in spec at around 750 rpms. Although, the timing jumps +/- 2* around 15* mark on the flywheel. Upon removing the distributor, the end that goes into the exhaust cam can fully slide side-to-side across the roll pin. It can also rock back and forth a little. It spins freely. We came to the conclusion that it could be bad bushings.
Also, could the timing belt tension cause this?
Thoughts?
jdm_crx91
Feb 18, 2008 08:49 PM
D-meet07
Sep 13, 2005 09:23 AM
acclude435
Dec 3, 2004 03:31 PM
davekaro
Apr 3, 2004 02:38 PM
Stewie
Jun 3, 2002 06:24 PM
